Snapdragon 865 smartphone chip
    • Kryo 585 CPU: Octo-core architecture; 1 ARM Cortex-A77 (2.84GHz, prime) + 3 ARM Cortex A-77 (2.4GHz, performance) + 4 ARM Cortex-A55 (1.8GHz efficiency)
    • Memory support: embedded LP-DDR5 (2750MHz), LPDDR4x (2133MHz); up to 16GB
    • Adreno 650 GPU: displays up to 4K/60Hz, or 3200x1800/144Hz; HDR10+ support
    • Spectra 480 ISP: 200 megapixel still photos; 4K video (with 64Mpixel stills) or 4K HDR or 4K/120; 8K capture; 720p at 960fps; Rec 2020, 10-bit color
    • Hexagon 698: Total Harmonic Distortion + Noise (THD+N) Playback: -108dB
    • Connectivity (5G): X55 5G modem (7.5Gbps down, 3Gbps up, via 5G); mmWave (800MHz bandwidth, 2x2 MIMO), Sub-6GHz (200 MHz bandwidth, 4x4 MIMO); LTE support (CBRS, WCDMA, HSPA, TD-SCDMA, CDMA 1x, EV-DO, GSM/EDGE)
    • Connectivity (Wi-Fi): FastConnect 6800 (802.11ax, 802.11ac Wave 2), 1.774 Gpbs peak speeds,1024 QAM, OFDMA, ; 60GHz WiFi, 10Gbps peak speeds; always-on ambient Wi-Fi sensing
    • Connectivity (Bluetooth): Bluetooth 5.1, with support for Qualcomm aptX specifications
    • Qualcomm Sensing Hub: Always-on far-field detection and echo cancellation; support for multiple voice assistants
    • Power: Quick Charge 4+ plus Quick Charge AI
  • 6 Replies sorted by
    569 x 842 - 94K
  • Geekbench scores
    Single core
    Multicore
    769 x 232 - 29K
    774 x 236 - 31K
  • More photos
    800 x 596 - 52K
    800 x 610 - 55K
    800 x 612 - 43K
    800 x 582 - 46K
  • Impresive footage.
  • now if someone can make a phone with a popup evf...
