Not much difference at the top, but it looks like Olympus just edges out all the others in a crowded field.
Most lenses are at their "best" when stopped down about 2 stops so it's not completely unexpected that an f/2 lens stopped down two stops has an edge over an f/1.2 lens stopped down 3 1/2 stops. :)
Funny that the F2 tests better at F4.
Lens design is by Sigma (according to patent)
New firmware v1.1
https://cs.olympus-imaging.jp/en/support/imsg/digicamera/download/software/fourthirds_olylens.cfm
Review
Olympus's recent Zuiko Pro lenses, both zooms and primes, have all shown stunning results when it comes to sharpness, and the 45mm f/1.2 Pro is no exception. Even wide open, the lens displays excellent sharpness across the entire frame. We measured a slight increase in sharpness if you stop down slightly, down to f/2.8, but overall, increase in sharpness is quite subtle compared to wide open. Although with a lens like this, you're unlikely to shoot it stopped down significantly, but nevertheless the 45mm f/1.2 still offers fantastic sharpness at f/11. We do, finally, see some diffraction-related softness appear by f/16, the lens' narrowest aperture.
https://www.imaging-resource.com/lenses/olympus/45mm-f1.2-pro-m.zuiko-digital-ed/review/
Our third interview concerning this lens
Measurements
https://www.lensrentals.com/blog/2018/03/finally-some-more-m43-mtf-testing-are-the-40s-fabulous/
Our Interview about Olympus Pro prime lenses lineup
It is really sharp lens - review
Best fixed focal length lenses are able to reach 80-85 lpmm and the decency level we set near 47-49 lpmm. Of course we clearly indicated that these values could change with the enlargement of our tests database. The last resolution record achieved by the Panasonic Leica DG Elmarit 200 mm f/2.8 POWER O.I.S.,which maximum result exceeded 91 lpmm, makes that decision fully justified. Currently we should say that the decency level is set within 48-50 mm range and the best fixed focal primes should be able to get to a level of about 85 lpmm or higher.
