Canon UHD-DIGISUPER 51 and 7×10.7 KAS S 8K lenses
  • UHD-DIGISUPER 51 and 7×10.7 KAS S Lenses Provide Cutting Edge Imagery Solutions for Sports and Event Production
    Canon U.S.A., Inc., a leader in digital imaging solutions, today announced the launch of its first two 8K Broadcast lenses: the UHD-DIGISUPER 51 (SP51x15.5B), a long-zoom field lens, and the 7×10.7 KAS S, a portable zoom lens. These two new zoom lenses are compatible with 8K broadcast cameras equipped with 1.25-inch sensors.
    “8K broadcasting equipment is the newest frontier for covering sporting events and documentary productions around the globe,” said Kazuto Ogawa, president and chief operating officer, Canon U.S.A., Inc. “Through the addition of our first 8K broadcast lenses, Canon is cementing our position on the cutting edge of the latest ultra-high resolution digital imaging solutions.”
    UHD-DIGISUPER 51 8K Lens
    The UHD-DIGISUPER 51 8K field zoom lens provides high-quality optical performance for 8K broadcast cameras from the center to the periphery of the screen. The lens is built with the world's highest1 51x zoom, as well as the world's longest1 focal range from the wide-angle end of 15.5mm to the telephoto end of 790mm. In addition, the lens also features a built-in 1.5x extender that increases the maximum focal length to 1185mm. With the ability to realize high magnification, this lens provides users the same operability as a conventional 2/3-inch HDTV or 4K field zoom lens, allowing them to switch to 8K video shooting and production without changing the shooting style.
    7×10.7 KAS S 8K Lens
    Featuring a 7x zoom that covers a focal range of 10.7-75mm, the new 7×10.7 KAS S is ideal for a variety of broadcasting applications. From the center of the screen to the corners of the periphery, this lens has the resolution and contrast compatible with 8K broadcast cameras, while also having the same operability as a conventional 2/3-inch HDTV or 4K portable zoom lens. The 7×10.7 KAS S is equipped with key features designed to provide customers with a high-quality, user-friendly experience, including the mobility required for on-the-move shooting.
    1.25-Inch Image Format Size for 8K UHD Live Television
    The early experimental 8K UHD live television coverages of sporting events proved critical to determining the image format size that could deliver the essential depth of field while also ensuring an individual image sensor photosite size that could sustain 8K MTF, adequate dynamic range, and luma signal to noise.
    A 1.25-inch image format size balances those imaging parameters in tri-sensor cameras for 8K UHD live television. The 1.25-inch image format has a diagonal of 18.5mm as compared to the smaller 11.0mm of the 2/3-inch format and the larger 28.2mm of the Super 35mm format.
    The 7×10.7 KAS S will be available by special order beginning in January 2020, and the UHD-DIGISUPER 51 will be available by special order beginning in May 2020. For interest or inquiry about either lens please contact your local Canon representative. To learn more about Canon broadcast lenses, please visit www.usa.canon.com.
  • 1 Reply sorted by
    800 x 515 - 34K
