DJI Ronin-S Gimbal
  • 28 Replies sorted by
  • Lanparte has released the Ronin S L plate for vertical shooting. It enables the user to switch to vertical shooting easily and quickly for doing videos for Instagram, Facebook, Twitter, TikTok, etc.
    The bracket is a customized unit which fits the DJI Ronin-S gimbal for vertical shooting with is popular with social media. The camera can be mounted on the bracket on the vertical axis and can be bracket can be mounted on either side of the plate for left or right mounting. The user can remove the camera from the gimbal in seconds because of the ARCA mount. The mounted camera then can be put horizontally on a tripod that is ARCA compatible.
    The high quality hollowed out triangular design reduces the weight of the bracket and makes the bracket light and strong. There is a ruler on the bottom like the original plate and anti-skid rubber. The plate does not interfere with the gimbal motor. Also the Ronin-S original control cable can be used. Lanparte supplies 3 counterweights for heavier cameras which include most DSLR’s and mirrorless cameras for a better balance.
    Clears camera strap connectors image
    800 x 954 - 246K
    810 x 810 - 108K
    810 x 810 - 71K
    810 x 810 - 72K
    810 x 810 - 138K
    810 x 810 - 83K
