Fuji X-Pro3 camera - strictly for photo guys
    • 26Mp APS-C BSI-CMOS Sensor (Sony made)
    • Video
      • 4096 x 2160 @ 30p / 200 Mbps, MOV, H.264, Linear PCM
      • 4096 x 2160 @ 25p / 200 Mbps, MOV, H.264, Linear PCM
      • 4096 x 2160 @ 24p / 200 Mbps, MOV, H.264, Linear PCM
      • 4096 x 2160 @ 23.98p / 200 Mbps, MOV, H.264, Linear PCM
      • 3840 x 2160 @ 30p / 200 Mbps, MOV, H.264, Linear PCM
      • 3840 x 2160 @ 25p / 200 Mbps, MOV, H.264, Linear PCM
      • 3840 x 2160 @ 24p / 200 Mbps, MOV, H.264, Linear PCM
      • 3840 x 2160 @ 23.98p / 200 Mbps, MOV, H.264, Linear PCM
      • 1920 x 1080 @ 120p / 200 Mbps, MOV, H.264, Linear PCM
      • 1920 x 1080 @ 100p / 200 Mbps, MOV, H.264, Linear PCM
      • 1920 x 1080 @ 60p / 200 Mbps, MOV, H.264, Linear PCM
      • 1920 x 1080 @ 50p / 200 Mbps, MOV, H.264, Linear PCM
      • 1920 x 1080 @ 30p / 200 Mbps, MOV, H.264, Linear PCM
      • 1920 x 1080 @ 25p / 200 Mbps, MOV, H.264, Linear PCM
      • 1920 x 1080 @ 24p / 200 Mbps, MOV, H.264, Linear PCM
      • 1920 x 1080 @ 23.98p / 200 Mbps, MOV, H.264, Linear PCM
    • 1,620,000Mdot strange LCD
    • Electronic and Optical EVF - 3,690,000Mdots
    • Dual SD/SDHC/SDXC slots
    • USB 3.1 Gen 1 port, mike port
    • Lacks headphone port
    • 802.11b/g/n + Bluetooth
    • Weather sealed
    • 497 g
    • 141 x 83 x 46 mm
    • $1799 for body, $1999 DR finish, available at
  • 21 Replies sorted by
  • They had a concept camera with this IDIOTIC display. They keep listening the people of "pure photography" - which should buy a film Leica but don't have money or talent.
  • PR
    *The X-Pro3 uses the back illuminated 26.1MP X-Trans CMOS 4 sensor and the X-Processor 4 image processing engine for superb image & 4K video quality and autofocus performance.**
    The X-Pro3 uses an improved algorithm to enable autofocus at the minimum luminance of -6EV, which is near pitch-darkness. The camera features a new HDR shooting function, which combines multiple continuously shot images of different exposure levels to expand the dynamic range. The tool, designed to recreate the vast dynamic range of light conditions that exist in nature, produces natural tones without causing exaggerated amplification of colour tones.
    The camera handles multiple exposures of up to 9 frames in the Additive, Average, Comparative Bright or Comparative Dark mode to combine images taken from multiple viewpoints or at different times into a single image. You can apply different Film Simulation modes to each of the frames to create a multi-layered collage.
    The exterior of the camera body is made of titanium, which gives the camera additional strength and corrosion resistance. It is combined with premium quality coating giving it a sleek, elegant appearance. The internal framework of the camera body is made from magnesium alloy. Weather sealing has been applied at 70 points to give the camera advanced dust and moisture resistance. The camera is also capable of operating in temperatures as low as -10℃, allowing users to be on location and not having to worry about the weather.
    The X-Pro3 for the first time has an AF range limiter function, which has been available only on a limited number of lenses until now. You can select from two preset values or use the focus ring to specify any focus range. This gives the focus preset function available to all XF lenses.
    Users can switch between the optical viewfinder (OVF), which provides a constant view of your subject without any time lag, and the electronic viewfinder (EVF), which allows you to check exposure while you shoot. The EVF uses a 3.69-million-dot organic EL panel with advanced display performance. The organic EL panel boasts a high contrast ratio of over 1:5000 and the maximum luminance of 1500cd/m2 to display the finest details even in shadows and highlights. It also covers 97% of the sRGB colour space, giving more accurate colour reproduction.
    EVF display options in the “Boost” performance mode now includes “Smoothness priority” where a black frame is inserted between each of the frames at approx. 100fps to provide a smoother appearance with a minimal sense of residual images, giving an equivalent refresh rate of approx. 200fps. This option is recommended when you are taking pictures of fast moving subjects and need to track the erratic motion.
    The camera also features the “Electronic Range Finder” function, in which a small EVF window is displayed within the OVF to help checking electronic settings. The EVF window displays live view, enlargement of an AF point and pictures taken, improving the usefulness of the OVF.
    The 1.62-million-dot high-resolution tilting LCD touchscreen display, can flip approx. 180 degrees, allowing you to shoot from the hip, at ground level or with the camera above your head. The screen offers a wide angle of view and delivers high contrast yet natural colour reproduction to provide a clear and high quality view.
    The rear 1.28-inch colour Memory LCD, protected with toughened glass, displays shooting settings regardless if the camera is turned on or not. The screen can be set in the “Classic” mode which displays Film Simulation, white balance and other image settings reminiscent of film cameras, or in the “Standard” mode for displays shutter speed, ISO sensitivity, the number of remaining frames and other shooting settings in plain numbers and icons.
    “CLASSIC Neg” mode has been added to the Film Simulation function, which simulates colour negative film traditionally chosen for everyday snapshots. The colours, precisely controlled for each level of brightness, create a rich chromatic contrast to add extra definition to the image.
    The Black & White adjustment function, originally introduced to the X-T3 and X-T30 to apply warm and cool tones to monochrome images, has been updated as the “Monochromatic Colour” function. The X-Pro3 now allows you to choose the key colour from a matrix of Warm / Cool tones and Magenta / Green hues, incorporating the rich gradation into your images to create photographs with a personal twist.
    “Clarity setting” has been included as an image quality parameter to complement the existing Highlight Tone, Shadow Tone and Sharpness. Texture and outlines of subject can be accentuated or softened while retaining gradation of colours to control the overall look of a picture.
    The Grain Effect function, which simulates the photographic film, has been evolved so that you can adjust “strength” and “size” to attain a more precise control over graininess, instead of having just two options of “strong” and “weak” graininess in previous models.
    “Highlight Tone” and “Shadow Tone” options, have been integrated into the “Tonal Curve” setting so that you can intuitively adjust settings while checking the tonal curve.
    Compatibility with 3rd party software has been improved so they can now read ratings given to pictures using the “Rating” function.
    The functionality of the “Q” quick menu has been improved. You can now choose the number of icons to be displayed in the menu from 16, 12, 8 or 4. “Transparent” has been added as a new background option, allowing you to change the settings but ensuring you won’t miss a photo opportunity.
    The X-Pro3 has a USB Type-C port (USB3.1 Gen1), to charge the camera’s battery and transfer data.
    Size : 140.5 x 82.8 x 46.1mm
    Weight : 497g
    704 x 505 - 45K
    705 x 508 - 44K
    716 x 683 - 45K
    645 x 696 - 46K
    641 x 703 - 47K
  • PR
    FUJIFILM North America Corporation is pleased to announce the launch of the FUJIFILM X-Pro3, the latest rangefinder from the X Series range of mirrorless digital cameras, and perfect for photographers on the move who want top-level features, a low profile, and reliable durability.
    Created with street photographers and photojournalists in mind, the features of the X- Pro3 are designed to keep the photographer focused on the subject. Its revolutionary hybrid OVF/EVF and hidden LCD touchscreen keeps the photographer in the moment, while its state-of-the-art imaging sensor and high-quality 4k video ensure spectacular results. X-Pro3 is a true photographer's tool that combines all the feeling of film with all the ease and quality of digital.
    The X-Pro3 is one of the most durable camera bodies in FUJIFILM camera history, thanks to the exterior use of titanium, known for its outstanding strength-to-weight ratio. Two color variations will be available with additional DuratectTM (DR) surface- hardening technology for extra toughness and premium finish. The X-Pro3 uses the back illuminated 26.1MP X-TRANS CMOS 4 sensor and the X-Processor 4 image processing engine, first seen in the FUJIFILM X-T3 and then the FUJIFILM X-T30. Using this combination and new firmware, the phase-detection AF now works down to a luminance of -6EV; close to absolute darkness. Also new is CLASSIC Neg. Film Simulation mode, which is designed to simulate color negative film that was normally used for everyday snapshots.
    More information about X-Pro3
    New OVF/EVF Combination
    Great photography is all about freezing natural moments in time and X-Pro3's impressive hybrid viewfinder ensures you are always fully immersed in that moment, without influencing it. The optical viewfinder (OVF) uses a 0.5x magnification and parallax-correcting frame lines to provide an uninterrupted and true-to-life view of what's in front of you. It also allows you to see outside the frame so that you are always ready to catch the approaching action. Additionally, the 3.69M-dot OLED electronic viewfinder (EVF) offers a fast and high-quality representation of exactly how your image will look, with a 1:5000 contrast ratio for excellent clarity. When combined, this industry-leading technology provides an outstanding picture, helping to capture the world exactly as it is being seen.
    Hidden 180-Degree Tilt and Touchscreen
    Every aspect of X-Pro3 has been designed for photographers who like to live in the moment, but none more so than its hidden 1.62M-dot, tilting LCD touchscreen. When the LCD is closed, all that can be viewed is a mini-display showing essential settings, removing the distraction of a full screen while shooting. With your mind and your eye always on the scene in front of you rather than the scene you've just shot, you can find a connection not just with your subject, but also with your art. If seeking the perfect moment is instinctive to you, then look no further than X-Pro3 as your tool.
    Incredible Sensor, Processor, and AF Performance
    Lying at the heart of X-Pro3 is its state-of-the-art X-Trans CMOS 4 sensor and X-Processor 4 combination. This exceptional 26.1MP sensor uses a back-illuminated design to maximize quality and dynamic range, while its unique color filter array controls moiré and false color without the need for an optical, low-pass filter. Such outstanding imaging capability is complemented by the quad-core X-Processor 4. This powerful CPU not only ensures images are quickly and smoothly processed, but thanks to Fujifilm's new algorithm, boosts AF performance with precision face and eye detection right down to -6EV.
    Enhanced Body Design
    X-Pro3's timeless body design features a top and base plate constructed from titanium, which, despite being little more than half the density of stainless steel, is seven times more durable. In addition to classic black, the weather- sealed X-Pro3 is also available in DR Silver and DR Black, which utilize cold plasma technology for a scratch-resistant finish. This outstanding durability combines with a newly developed shutter release unit that ensures dependable precision and smoother, more responsive functionality to create a camera that can be relied upon to perform in nearly any situation.
    Unparalleled Color Reproduction and Film Simulation Modes
    Fujifilm's legacy in color science has given it legendary status among image-makers across the world. During its 85 years in the industry, Fujifilm has been responsible for some of the most iconic photographic films in history. The exceptional knowledge gained has been poured into Fujifilm's collection of 16 digital Film Simulation modes. This cutting-edge technology allows photographers to achieve stunning results straight out of camera and X-Pro3 introduces two exciting new additions to the Film Simulation mode collection: CLASSIC Neg. and MONOCHROMATIC Color.
    The X Series' first interchangeable lens camera, FUJIFILM X-Pro1, was released in February 2012, and its successor, FUJIFILM X-Pro2, debuted in March 2016 with vastly improved image quality and performance. The X-Pro Series has been embraced by many professional and enthusiast photographers who enjoy the classic rangefinder style, portability, and dials that enable intuitive operation. The X-Pro3 builds on the series' legacy as the ultimate solution for photographers on the move who know the value of being in the moment.
    The X-Pro3 camera will be offered with manufacturer's suggested retail prices as follows:
    • $1,799.95 USD Black
    • $1,999.95 USD DR Black or DR Silver
    • $2,399.99 CAD Black
    • $2,699.99 CAD DR Black or DR Silver.
    X-Pro3 is expected to go on sale in late Fall 2019. For more information, please visit https://fujifilm-x.com/en-us/x-pro3
  • From Japanese presentation
    793 x 587 - 63K
    780 x 588 - 67K
    749 x 584 - 103K
    What other APS-C sensors at the moment are using 26Megapixels?
    As I think the recent ones have been: 18 / 20 / 24 / 28
  • New firmware v1.03
    • The phenomenon is fixed that in rare cases, a freeze could occur.
    • The phenomenon is fixed that the color tone of recorded images is not recorded correctly in AF-C mode and continuous shooting.
    https://www.fujifilm.com/support/digital_cameras/software/firmware/x/xpro3/index.html
  • Gariz cases
    757 x 614 - 56K
    775 x 575 - 58K
  • Issue with lenses
    576 x 713 - 100K
    582 x 474 - 37K
