150mm T3.0 Irix Cine Macro 1:1 Lens
  • 6 Replies sorted by
  • Irix 150mm T3.0 Macro 1:1 is a full frame (43.3 image circle), 8K ready lens with T value 3,0 to 32. The lens will be available in four mounts (Canon EF, Sony E, Olympus/Panasonic MFT, PL mount) and delivered to dealers early August 2019. Suggested retail prices are as follows:
    • Irix 150mm T3.0 Macro 1:1 Canon EF mount 1195 € (VAT incl.) / US$1195
    • Irix 150mm T3.0 Macro 1:1 Sony E mount 1195 € (VAT incl.) / US$1195
    • Irix 150mm T3.0 Macro 1:1 Olympus/Panasonic MFT mount 1195 € (VAT incl.) / US$1195
    • Irix 150mm T3.0 Macro 1:1 Arri PL mount 1295 € (VAT incl.) / US$1295
    The launch of our 150mm T3.0 Macro 1:1 is a special moment for the Irix team. The first ever Irix Cine lens is a result of not only hard work, but also countless hours of extensive development filled with passion, innovative creation and cooperation between engineers and the design team. The project, now finalized, brings us pride – and lets us present to the world an entirely new Cine lenses line.
    The close collaboration between Irix designers and professional filmmakers showed how powerful are close-up shots as a medium of expression. With the Irix Cine 150mm such freedom of creation can be expanded even more – to create countless new artistic possibilities.
    From the very beginning, our intention was to provide the cinematographers with the most advanced and versatile lens in this particular focal range. The moderate focal length of the Irix Cine 150mm T3.0 Macro 1:1, combined with its exceptional functionality, makes it a fantastic tool to discover new fields of creation – ones that were not easily accessible for enthusiasts of filmmaking before. Release of the 150 mm T3.0 Macro 1:1 as the first lens in the Cine line is a great opportunity to share ideas and unique solutions developed especially for the Irix Cine lenses.
    Compatibility.
    The lens is compatible with standard sizes and systems used in cinematography. It’s equipped with a lens hood that can be easily replaced with a typical matte box of a 95mm diameter. The front of the lens is equipped with a 86mm filter thread. For extra stability when filming, the lens can also be fixed to a cage with a lens foot (included in the kit) with a typical ¼ mount thread. All future Irix lenses will have gears at same height for greater comfort of use.
    Ease of use.
    Without a doubt, focus ring rotation aka focus throw is a very important factor in the macro lens. For that reason, we constructed a MST mechanism with a 270 degrees rotation angle. The aperture ring can be rotated within a range of 75 degrees for more accurate light control.
    Loaded with functionalities.
    The lens was crafted with numerous new solutions and fresh ideas in mind. The front of the lens is equipped with the Magnetic Mount System (with an innovative lens hood as its first element) for an effortless installation of additional accessories. The Adaptive Ring for follow focus not only lets the filmmaker enjoy full functionality of the follow focus systems, but also makes the lens more user-friendly when follow focus is not used. All for one reason – greater versatility.
    Ready for action.
    The lens is weather-sealed (equipped with 5 rubber rings, PL mount 4 rings) and lightweight. The construction is made of durable magnesium alloy, which provides endurance but weights only 1105g (Canon EF version). The built makes our lens well-balanced in use with mid-size camcorders as well as DSLR/mirrorless cameras. Engraved letters are filled with UV reactive paint for better readability in low light conditions. All to make your work easier and more pleasant.
    Quality as top priority.
    The lens is 8K ready, built on 12 optical elements construction, internal focusing and equipped with an 11 blade aperture. All to give highest possible image quality, bokeh, performance and lowest possible focus breathing. What else is needed to enjoy the Irix quality?
    All features, functionalities and possibilities of the Irix Cine 150mm T3.0 Macro 1:1 are shown on the infographics below.
    714 x 530 - 56K
    737 x 571 - 46K
  • PR
    IRIX, known for high mechanical and optical quality, pleasantly presents the 150mm T 3.0 macro 1:1 – the first of a new cinematography line of the full-frame sensor lenses.
    The new line of Irix Cine Lenses is created in close cooperation with professional filmmakers; their ideas and suggestions were an important factor in the design process. The designers earlier experience in the field of photography led us to create new and better solutions for the Irix Cine products.
    Proven optics
    The Irix Cine 150mm T3.0 Macro 1:1 is the first lens in a new line of full frame sensor cine lenses, ready for 8K UHD. It’s complex optical system is based on the same optical layout used in the Irix 150mm f/2.8 Macro 1:1. The lens consists of 12 optical elements arranged in 9 groups, four of which are high refractive index (HR) glass, and three low-dispersion glass (ED). Because of these elements, this lens offers superb high resolution, nearly zero chromatic aberration and has almost no visible distortion (as low as 0,1%). The optical system is equipped with an internal focusing system. The lens was designed to have as little breathing as possible.
    Refined mechanics
    In the eyes of a camera operator, a good and tough housing is of major importance. Irix is known for fine mechanical constructions, and in the Cine range we pushed this even further, focussing on superb operation ergonomics and a high precision mechanism. Quiet and smooth rotation of the focus ring was achieved thanks to the new MST lens positioning system – created specially for the Irix Cine range. The Multi Start Thread mechanism, in combination with a sealed housing, ensures durable and long-term operation of the lens in various atmospheric conditions even in the most demanding situations. The rotation angle of the focus ring is increased to 270 degrees, which makes focusing easy and accurate at any range. The lens will be available with both metric and imperial markings.
    Highest attention has been paid to the aperture mechanism in these optics, where eleven iris blades with rounded edges create great bokeh and sharpness. The Irix Cine 150mm also significantly reduces the diffraction effect when filming at low aperture values. The de-clicked aperture ranges from T3.0 to T32. The aperture ring rotates 75 degrees.
    Unique design and well thought-out ergonomics
    The Irix Cine 150mm T3.0 Macro 1:1 lens stands out for it’s great ergonomics and design. The side edges of the focus gear-rings are shielded by a special ring, providing a larger area for better manual handling – whilst still compatible with follow-focus systems. Further information about the Adaptive Ring System will be provided later. The markings on the lens are laser engraved and treated with UV fluorescent paint, to improve the readability in low light conditions.SAR
    Prepared for all weather conditions
    The Irix Cine 150 mm T3.0 Macro 1:1 has been designed as a versatile tool in the hands of a filmmaker, built to withstand various weather conditions. The housing is equipped with several seals to create a barrier for dust, rain and accidental splashes of water. The sealed construction ensures the safety of both the optical lens system and the camera sensor.
    Innovation as standard
    The exceptional functionality and innovative solutions are a distinctive feature of all Irix products. This lens has been equipped with an unique Magnetic Mount System for accessories. The MMS system allows quick and easy attachment of variety dedicated accessories. The first of the new MMS accessories is the detachable and reversible lens hood (included with a lens). More accessories coming soon.
    Created to be part of the cine gear family
    Making innovations doesn’t mean we resign from the industry standards. We know how important compatibility is for a filmmaker, with other accessories. Irix Cine lenses have standardized front diameter 95mm for matte box, 86mm front filter thread, unified distance between gear-rings within the whole family range (future developments), standardized 0,8 pitch module gears, unified angles of rotation, and similar weight. The Irix Cine 150mm T3.0 lens is equipped with a removable support foot with a 1/4 thread, which stabilizes the lens when using a follow focus system, and protects the camera mount. The support foot can be attached on the bottom or top of the lens for convenience of use.
    Available camera mounts
    The new Irix Cine 150mm T3.0 Macro 1:1, as well as future Irix Cine lenses, will be offered in following lens mounts: Canon EF, Sony E, MFT and PL.
    Price and availability
    The price and availability of the Irix Cine 150mm T3.0 Macro 1:1 lens will be announced shortly.
    Main stuff
    • 12 optical elements in 9 groups (4 HR and 3 ED lenses)
    • Internal Focusing -MST focusing mechanism -Sealed in 5 crucial points
    • Rear element in a fixed position (anti-dust protection)
    • Detachable and reversible lens hood
    • Lens hood with magnetic lock
    • 11 rounded aperture blades
    • MMS – magnetic mount system (patent pending)
    • Standardized 0.8 pitch mod cine gears
    • 86mm front filter thread -95MM standardized front diameter for cine accessories
    • Precise laser engraved markings filled with UV reactive paint
    • Lens support with 1/4″ thread
    • Two-position detachable lens support
    • Adaptive ring for follow focus system (patent pending)
    • Focus ring with 270° focus throw available with metric or imperial units
    • Aperture ring rotation 75°
    800 x 472 - 34K
