AMD Zen 2 aka Ryzen 3000 CPUs details
  • 131 Replies sorted by
  • Ryzen Performance on X570 compared to X470
    Issue with memory write speed persists
    596 x 469 - 41K
    595 x 311 - 26K
    595 x 467 - 44K
    800 x 601 - 87K
  • Some Ryzen 5 3600 benchmarks from https://elchapuzasinformatico.com/2019/06/amd-ryzen-5-3600-x470-review/
    Memory has some issues on writing
    In short - Ryzen 1700 still is best bang for the buck considering used local or aliexpress prices.
    706 x 562 - 51K
    712 x 375 - 30K
    700 x 553 - 46K
    705 x 559 - 53K
    715 x 554 - 55K
    800 x 349 - 31K
    800 x 409 - 56K
    800 x 391 - 43K
    800 x 371 - 43K
    800 x 343 - 43K
    800 x 377 - 43K
    800 x 433 - 57K
    800 x 348 - 34K
    800 x 453 - 40K
    800 x 442 - 37K
  • Architecture
    800 x 394 - 43K
    800 x 394 - 62K
    800 x 396 - 57K
    800 x 354 - 42K
    800 x 354 - 42K
    800 x 421 - 42K
    800 x 375 - 48K
    800 x 370 - 56K
    800 x 377 - 55K
  • Lot of Ryzen 2 tech slides
    800 x 337 - 42K
    800 x 412 - 39K
    800 x 411 - 59K
    800 x 431 - 55K
    800 x 431 - 52K
    800 x 402 - 59K
    800 x 363 - 59K
    800 x 417 - 47K
    800 x 357 - 47K
    800 x 394 - 90K
    800 x 352 - 58K
  • Interesting.
    Seems like Ryzen 1700 or 1700X are sweet spot for now for poor video editors. They are much cheaper and only 20-25% slower compared to latest 3000 series.
  • Ryzen 5 3600 Cinebench results
    If we look at Ryzen 1600 results in comparison it is 27% lower, but on same frequency difference is only 12,5%.
    Ryzen 1600 at 3,9Ghz will make 1386 (most CPUs) and at 4.0Ghz will be 142, almost same as stock 3600.
    It is just one issue, for 12-13% advantage you need to pay 2x more.
    504 x 470 - 52K
    446 x 678 - 53K
  • Single core performance leak
    750 x 430 - 85K
  • Very complex board for CPU - 12 layers
    Unusual way to connect chiplets to board
    Really risky or may be it is done as they know that such CPUs won't live more than certain amount of time.
    800 x 380 - 72K
    800 x 431 - 49K
    704 x 392 - 39K
    708 x 395 - 39K
    703 x 389 - 31K
  • Ryzen 3950X price will be $749 (you can get 1950X Threadripper + x399 motherboard for $800-840).
    800 x 368 - 49K
    800 x 453 - 55K
  • Ryzen 9 3950X can be announced on E3
    748 x 225 - 38K
  • Ryzen 3000 is much different from 1st Ryzen in one regard
    12 core model has 6 cores on each chipset working.
    Same can be actually true for most 8 core models that will be 6+2 or 4+4, but rarely 8+0.
    https://adoredtv.com/zen-2-chiplets-why-two-is-better-than-one/
    AdoredTV had been right that all good 8 core chiplets go to Epyc now as profits per one is around 3-5x more compared to consumer product.
    It also tell us that 7nm process is still not mature and has lot and lot of issues.
    With Ryzen two years ago AMD idea had been same, but due to very good production yields they actually intentionally killed second chiplet, so processor came with 8 core fully functional one and another one where 4-6 cores had been good, but it had been disabled.
    Same is true for Threadripper, as almost all of 2 unused chiplets had from 4 up to 8 cores perfectly functional, but to keep prices of higher core count models very high AMD intentionally destroyed them. Yes, like farmers during great recession.
    Intel is doing same, where around 80% of their 2 core models could perfectly had at least 4 cores, but they had been disabled to not ruin prices.
    This is why all people whoa re doing such making enormous damage to society must find their place on the trees.
  • An overclocked 16-core Ryzen based on Zen2 architecture would score 4346 points in Cinebench R15. That’s more than twice than Ryzen 7 2700X and 2.5x more than Ryzen 7 1800X.
    Only multi-threaded performance was shown. The CPU was running at a voltage between 1.428 and 1.572V. This allowed the 16-core AM4 processor to run at 4.1 – 4.25 GHz.
    732 x 878 - 105K
    678 x 343 - 44K
    AMD introduced the Ryzen 7 3800X, an 105W 8C/16T processor with a 3.9 GHz base and 4.5 GHz boost.
    Ryzen 7 3700X. This 8C/16T CPU comes with a 4.4 GHz boost and 3.6 GHz base frequency, 36MB of total cache, and a 65W TDP.
    The Ryzen 9 3900X comes with 12 cores 24 threads, a 4.6 GHz boost, 3.8 Ghz base, 70MB of cache, and a 105W TDP.
    Ryzen 7 3700X for $329, the Ryzen 7 3800X for $399, and Ryzen 9 3900X for $499.
    Lack of 16 core CPU!
    Just for reference
    • RYZEN 7 1700X 8-Core (3.4/4) is $189 now in US
    • RYZEN 7 2700 (3.2/4.1) is $209 now in US
    • RYZEN 7 2700X (3.7/4.3) is $284 now in US
    • Threadripper 1950X 16-Core / 32 Threads 3.4 GHz/4Ghz is $499 now in US
    So we can see AMD following Nvidia approach where despite better performance you start paying more for same performance unit.
  • DDR4 speed support
    It is from some MB docs.
    Note that it is usually also MB design that limits real DDR4 speed.
    588 x 233 - 34K
