The LUMIX G90 is a true hybrid camera, with equal importance given to its extensive video capability.
It can record unlimited 4K video (3840x2140) at 30p/25p (50Hz Area)/30p (60Hz) or 24p in addition to Full HD (1920x1080) at 60p/50p (50Hz Area), 60p (60Hz Area) with full-time AF. High Speed Video can also be utilised to record slow-motion video in Full HD at 120fps (1/4x), 90fps (1/3x) and 60fps (1/2x).
Real-time image output to an external monitor in 4:2:2 / 8-bit*1 via an optional micro HDMI cable is available, while V-Log L is pre-installed for wider dynamic range for colour rendering in post-production. Additionally, a 3.5mm microphone jack for high-quality audio recording is included, as well as a headphone socket.
The G90 features LUMIX’s well-known 4K Photo modes. Giving users the ability to extract fleeting moments at 30fps from a 4K video, it’s now even easier thanks to a new Auto Marking function which automatically detects frames with changes to the image. Sequence Composition has also been added for creating “stromotion” images by combining multiple images into one shot for a fun effect.
Panasonic Lumix DC-G95 Mirrorles with 12-60mm OIS Lens W/Hoya 58mm UV/CPL Filter for $698
Can also select lot of free bundles, like flash or software.
That's a very good price--I can't understand why they cropped the video for 4K....
Panasonic LUMIX G95 20.3 Megapixel Mirrorless Camera, 12-60mm F3.5-5.6 Micro Four Thirds Lens, 5-Axis Dual I.S. 2, 4K 24p 30p Video, Pre-Installed V-Log, $699
https://www.amazon.com/Panasonic-Megapixel-Mirrorless-Pre-Installed-Touchscreen/dp/B07PZB47HN
GH1 is 11.6 stops photo DR also.
https://www.dxomark.com/Cameras/Panasonic/Lumix-DMC-GH1
This may be a better comparison. 7.8 stops but at higher ISO, it is still better than the competition.
Each site has its own definition of DR. Also it is PHOTO DR at full resolution.
Is this chart right ? The GH1 has 11.6 stops dynamic range. Is DR really that bad ?
I guess there is nobody who is "upgrading" from filming with a G85 to a G95 instead?
In a sense, this is the ultimate skippable camera, because no matter what you want to do with it, there are better choices. There is no single feature that stands out. It's unique in that respect.
                  UK deal for 809 GBP
Samples
https://www.dpreview.com/sample-galleries/7932302636/panasonic-lumix-dc-g95-g90-sample-gallery/
                  Panasonic Lumix DC-G95/G90 Review
For 4K video capture DC-G95 uses only a portion of it that's roughly equivalent to a 1" sensor.
The G95 will perform worse when light levels drop, since there's less surface area capturing light compared to cameras that use the full sensor width.
At default settings, the camera is a bit slow to focus on a new subject, though that can be adjusted. The 'wobble' from the DFD autofocus system doesn't make for compelling footage.
https://www.dpreview.com/reviews/panasonic-lumix-dc-g95-g90-review/
Review in Russian
Firmware Version v1.3
- Improved compatibility with the Panasonic LEICA DG VARIO-SUMMILUX 10-25mm / F1.7 ASPH. (H-X1025) digital interchangeable lens.
- Smooth aperture control is available during video recording.
- [Aperture Ring Increment] has been added with which users can choose the control method of the aperture ring from [SMOOTH] or [1/3EV] in photo shooting.
- Improved compatibility with the Panasonic Battery Grip DMW-BGG1.
- The Fn button on the Battery Grip can be customized in the camera’s custom menu.
https://av.jpn.support.panasonic.com/support/global/cs/dsc/download/index.html
Exposure Latitude Test
