Official Apple Logic Pro X Topic
  • 30 Replies sorted by
  • Logic Pro X review
    Apple has done a great job of simplifying the entire interface without actually removing much. In fact, it’s actually been able to fit even more into the simplified UI by offering one-click access to functions that were in the past tucked away in menus or only accessible through modifier keys.
    Apple loops, list editors, and the browser feel less cluttered and easier to navigate thanks to the larger UI elements, but look relatively the same on the right hand side of the screen. The Library, on the other hand, has been given a new location on the left side of the screen next to the track headers and the Inspector.
    $200 is an insanely low price for everything that Apple has been able to do in Logic Pro X. It might have been a long time coming, but there’s something to be said for how much you get with Logic Pro these days for what used to cost upwards of $500. Close to 20GB of Drum Kit Designer samples isn’t the half of it.
    http://9to5mac.com/2013/07/26/logic-pro-x-review-powerful-new-features-a-simplified-ui-with-no-compromises-for-pros/
    704 x 282 - 64K
  • Logic Pro X v10.0.5 adds 3 new drummers, 11 new Drum Kit Designer patches, enhanced EQ features, offers improved performance and more.
    New features and enhancements
    • Includes 3 new Drummers and 11 new Drum Kit Designer patches.
    • Significant enhancements to Channel EQ and Linear Phase EQ plug-ins, including: ◾Redesigned, easier-to-use interface that's also accessible within the Smart Controls area
    • Double Precision processing provides more accurate filtering, especially for low frequencies
    • Oversampling option improves high-frequency clarity
    • Option to apply EQ only to stereo left, right, middle, or side signals
    • There is now an option to set the Piano Roll to a light background color.
    • Selected notes in the Piano Roll are now highlighted by a selection frame.
    • When Logic is stopped or in Play mode, the glyph on the Metronome button in the control bar now illuminates to indicate that "Click while recording" is enabled.
    • The Shuffle commands are improved (see Logic Pro X Help for details).
    User interface
    • There is now a command to assign region names to track names.
    • The waveform size in an audio region now adapts to the value of the region gain parameter.
    • Loops that belong to the same family can now be selected and changed using a new control in the region header.
    • Logic Pro X now assigns region and Mixer channel colors that are closer to the original colors when opening a project created in an earlier version of Logic.
    • Option-clicking a disclosure triangle in the Project Audio window now toggles all disclosure triangles in the window.
    • The Windows menu again lists all currently open windows.
    • The Mixer can now be reliably resized when in All mode.
    • Renaming multiple selected Mixer channels now reliably renames all channel strips in the selection.
    • When creating a duplicate track, the correct track icon and color are now assigned to the duplicate.
    • The song title is now automatically populated in the Share to iTunes dialog when sharing a song created in Logic 9 or GarageBand for iOS.
    • It's once again possible to browse or load patches onto the Output channel strip via the Library.
    • The View menu items One Track and Selected Regions in the Piano Roll are now disabled when Link mode is disabled.
    Performance
    • Improves processor balancing for multi-output software instrument configurations.
    • Improves handling of multiple displays on OS X Mavericks v10.9.
    • Resolves an issue that in some cases might cause audio clicks and pops when scrolling.
    • Moving an automation line while playing no longer spikes in CPU usages, or clicks and pops in the audio output.
    • Resolves an issue that could cause clicks and pops in the audio output when adjusting the gain or output level settings during playback in the various plug-ins.
    • Logic’s interface no longer freezes when using the Native Instruments Maschine controller to adjust two macro controls simultaneously.
    • Fixes an issue in which a warning about not enough memory might be displayed when performing Undo after editing a protected track.
    • Adjusting the frequency controls while playing audio through the Stereo Spread plug-in no longer causes audible zipper noise.
    • Improves the performance of scrolling when dragging regions in the Tracks area beyond the currently visible section.
    • Playing notes live into the Arpeggiator plug-in no longer sometimes leads to spikes in CPU usage.
    • Fixes an issue that could cause a spike in CPU usage when recording near the end of a project.
    • Logic 9 projects that contain a macro object in the Environment now behave more reliably when opened into Logic Pro X.
    • Multiple instances of the Scripter plug-in no longer have the potential to cause stuck notes.
    • The Scripter plug-in is no longer prone to causing stuck notes when using the Delay Note Until Next Beat preset.
    • Switching between presets in the Space Designer plug-in no longer sometimes results in noise.
    http://www.apple.com/ru/logic-pro/
  • Logic Pro X 10.0.7 Is on the streets:
    http://support.apple.com/kb/TS4498 Great news: "When Logic imports Final Cut Pro X XML, it now organizes audio tracks according to their assigned roles in Final Cut Pro."
  • New update focused on studios and Mac Pro buyers (also them)
    • Logic Pro X 10.4.5 will now support up to 56 processing threads on the Mac Pro
    • Logic Pro X 10.4.5 now supporting up to 1,000 audio tracks and 1,000 software instrument tracks
    • Logic Pro X now supports 1,000 auxiliary channel strips
    • 1,000 external MIDI tracks and 12 sends per channel strip.
    • Improved responsiveness of the Mixer and Event List when working with large sessions
