35-150mm F2.8-4 Tamron VC USD Lens
  • 19 Replies sorted by
  • I hope it is nice and compact
  • February 20, 2019, Saitama, Japan - Tamron Co., Ltd. (President & CEO: Shiro Ajisaka), a leading manufacturer of optics for diverse applications, announces the development of two new lenses for full-frame DSLR cameras—the 35-150mm F/2.8-4 Di VC OSD (Model A043) zoom lens and the SP 35mm F/1.4 Di USD (Model F045) fixed focal lens; and a new high-speed ultra-wide-angle zoom lens for Sony E-mount full-frame mirrorless cameras—the 17-28mm F/2.8 Di III RXD (Model A046).
    Tamron will display these new lenses at CP+ 2019, the World Premiere show for camera and photo imaging, beginning February 28 through March 3, 2019 at Pacifico Yokohama and at the Wedding and Portrait Professionals International (WPPI), February 27 through March 3, 2019 in Las Vegas.
    The lenses are expected to launch in the middle of 2019.
    Fast compact Portrait Zoom breaks new ground: 35-150mm F/2.8-4 Di VC OSD (Model A043)
    The new compact Model A043 is designed for fast handling and easy transport and features a zoom that extends from 35mm to 150mm, incorporating the 85mm focal length (often regarded as optimum for portrait shooting). It offers a fast F/2.8 aperture at the wide-angle end while maintaining a bright F/4 at the telephoto end. For close-focusing, the MOD (Minimum Object Distance) is 17.7 in across the entire zoom range. Delivering superb image quality, precisely placed LD (Low Dispersion) glass elements and aspherical lenses quash degrading optical aberrations. Furthermore, the Model A043 incorporates the Dual MPU (Micro-Processing Unit) system, which assures optimal AF performance and effective vibration compensation.
    788 x 528 - 35K
  • I sold most of my zoom lenses and only shoot with primes now for various reasons. I still have a Sigma 24-105 F/4 but I haven't used it in over a year so probably time to sell it.... I prefer to shoot with a 35mm lens on one body and a 85mm on another body over the traditional 24-70 70-200. Both ways have pros and cons.
    To bad it wasn't a constant F/2.8 but they probably did that to keep the cost and lens size down to a minimum. Very interesting lens I am curious to see how this lens performs at 35MM and 150MM. Time to speculate on pricing ;-) I am guessing this will sell for about $1300.00....
  • @Azo
    You just have such shooting scenarios.
    In real life limiting yourself such for video means that you can't frame proper as you can't move where you need to be. This is the same reason why zooms instantly wiped out primes as kit lenses back in the days.
    689 x 498 - 37K
    637 x 527 - 32K
    622 x 530 - 44K
  • Lens will be available for the Nikon F mount on May 23 and the Canon EF mount on June 20 at an MSRP of $799.
    • 19 elements in 14 groups
    • Maximum Aperture: F/2.8-4
    • Angle of View (diagonal): 63°26' - 16°25' (for full-frame DSLR cameras)
    • Minimum Object Distance: 17.7" Full zoom range
    • Maximum Magnification Ratio: 1:3.7 (f=150mm)
    • Filter Size: Ø77mm
    • Maximum Diameter: Ø84mm
    • Length for Canon: 5"
    • Length for Nikon: 4.9"
    • Weight for Canon: 28.1 oz
    • Weight for Nikon: 27.9 oz
    • Aperture Blades: 9 (circular diaphragm)
    • Minimum Aperture: F/16-22
    • Image Stabilization Performance: 5 stops (CIPA Standards Compliant)
    • Standard Accessories: Flower-shaped hood, Lens caps
    • Compatible Mounts: Canon EF mount, Nikon F mount
    Preorders
  • PR
    Tamron announces the launch of a new zoom lens, the 35-150mm F/2.8-4 Di VC OSD (Model A043), for full-frame DSLR cameras. Photographers everywhere, especially those who enjoy photographing people, can add wider range to their creative expression with the new Model A043 that extends from 35mm to 150mm and offers a fast F/2.8 aperture at the wide-angle end while maintaining a bright F/4 at the telephoto end. The lens will be available May 23 in Nikon mount and June 20 in Canon mount at approximately $799 at authorized Tamron USA retailers.
    The zoom range incorporates the 85mm focal length (often regarded as optimum for portrait shooting) and covers everything from full-body shots that include the surrounding environment to head-and-shoulders shots that stand out from a natural defocused "bokeh" background for which Tamron is renowned. The compact Model A043 is designed for fast handling and easy transport, measuring only 4.9 in long and perfectly balanced. On the technical side, three optimally placed LD (Low Dispersion) glass elements and three hybrid aspherical lenses quash various optical aberrations. Autofocus is exceptionally quiet with improved precision and speed thanks to the OSD (Optimized Silent Drive) DC motor. Furthermore, the Model A043 incorporates the Dual MPU (Micro-Processing Unit) system, which strikes the perfect balance between AF performance and effective vibration compensation. For close-focusing, the MOD (Minimum Object Distance) is 17.7 in across the entire zoom range. Providing greater flexibility when used outdoors, a Fluorine Coating and Moisture-Resistant Construction deliver extra measures of protection. The new 35-150mm portrait zoom is the most useful and most creative lens a portrait photographer can own.
    PRODUCT HIGHLIGHTS
    Superb optical performance meets requirements of high-resolution 50+ megapixel DSLRs
    Chromatic aberration and other imperfections that can diminish and degrade resolving power are thoroughly controlled by an optical design that combines three high-performance LD (Low Dispersion) glass elements with three hybrid aspherical lens elements aligned in perfect balance. The result provides the high levels of sharpness and contrast that today's high-resolution digital cameras require. Tamron's exclusive formula is optimized for exceptional performance around the mid-zoom 85mm range because that focal length has long been regarded as the preferred choice for portrait shooting. True to its designation as a "portrait zoom," the Model A043 leverages Tamron's optical technologies across the entire zoom range from wide-angle to telephoto to assure the finest experience at any setting. Making full use of the controlled depth-of-field properties only fast-aperture lenses can provide, Tamron employed proprietary simulation technologies to maximize the soft and natural "bokeh" defocused blur it has cultivated over many years. As a result, in-focus areas are rendered sharp and crisp down to the fine details that makes the subject stand out against a gently and beautifully blurred background. This technique is highly prized by portrait photographers and is potent for virtually every other type of photography.
    Outstanding performance even in strongly backlit situations
    Tamron's legendary BBAR (Broad-Brand Anti-Reflection) Coating works in harmony with an optical design that suppresses internal lens reflections to significantly reduce all traces of ghosting and flare. Because portraits are often shot under backlight conditions for impact, Tamron uses these advanced technologies to preserve high image quality even when strong sources of light---including the sun---are in frame.
    High-speed Dual MPU (Micro-Processing Unit) control system delivers fast and highly responsive autofocus performance plus outstanding vibration compensation
    Silent autofocus driven by OSD (Optimized Silent Drive) DC motor
    The OSD DC motor debuted in the 17-35mm F/2.8-4 Di OSD (Model A037) with favorable response. OSD technology reduces drive noise significantly (compared to previous DC motor-equipped lenses) while boosting autofocusing precision and speed by a wide margin. This eliminates noisy distractions during portrait shooting. Furthermore, the superior AF precision also provides more accurate tracking when locked on moving subjects.
    Outstanding VC (Vibration Compensation)
    Tamron's original VC system is enhanced in the A043 with an independent MPU dedicated to image stabilization without detracting from AF processing functions. Consequently, the VC (Vibration Compensation) achieves 5 stops*, according to CIPA Standards. This is highly beneficial when shooting at the telephoto end where camera movement is magnified. It's also very valuable when shooting at slow shutter speeds in dim lighting conditions.
    MOD (Minimum Object Distance) of 17.7 inches across the entire zoom range
    Close focusing, the A043 delivers an MOD of 17.7" at all focal lengths thereby expanding versatility and creative freedom. This allows portrait photographers to get in close to capture expressions and smaller details and allows them to adjust camera-to-subject distance with greater control. Even when shooting indoors where movement is restricted, users can make use of this feature to find the perfect shooting position and angle.
    Next-generation design is consistent with brand identity and is ergonomically superb
    Tamron has applied magnificent craftsmanship to a beautiful, intuitive design to produce a zoom with superior look and feel. From the outer contours of the lens, to the deftly worked Luminous Gold brand ring, the quality of this lens is second to none. Even details like the shape of the switch box and the precision and stability of the metallic mount reveal a commitment to functionality as well as design.
    Seals are located at the lens mount area and other critical locations to prevent infiltration of moisture and/or rain to provide Moisture-Resistant Construction. This feature affords an additional layer of protection when shooting outdoors under adverse weather conditions.
    Fluorine Coating
    The surface of the front element is coated with a protective fluorine compound that has excellent water- and oil-repellant qualities. The front surface is easier to wipe clean and is less vulnerable to the damaging effects of dirt, dust, moisture or oily fingerprints, allowing for much easier maintenance.
    Compatible with TAMRON TAP-in Console, an optional accessory
    The new Model A043 is compatible with the TAMRON TAP-in Console, an optional accessory product that provides a USB connection to a personal computer for easy updating of the lens's firmware as well as customization of features including fine adjustments to the focus position of AF and VC control.
    ** Covers a broad range of diverse scenarios when combined as a set with the 17-35mm F/2.8-4 Di OSD (Model A037) ultra-wide angle zoom**
    For the discerning travel photographer who wants to pack light while maintaining excellent image quality, the new 35-150mm zoom pairs perfectly with Tamron's 17-35mm F/2.8-4 Di OSD (Model A037) wide-angle zoom. The two lenses together cover 17mm to 150mm affording creative and versatile capture of landscape, street scenes, architectural details, food, street portraits and more, at a total weight of just 44.1 oz* with fast F/2.8 at the wide ends and F/4 at the tele end of each.
    765 x 509 - 51K
    766 x 539 - 49K
    766 x 536 - 50K
  • A very curious lens indeed!
    Wonder if it can find a niche market for itself vs 70-200 f2.8 (faster and more reach, but not anywhere near as wide) vs 70-200 f4 (greater reach but again not as wide, and also slower on the wide end as well) vs 24-70 f2.8 (a bit faster on the long end and wiiiider, but with much less reach)
  • that's different sony-e lens
  • @Readbook
    Thanks, I moved video reviews to proper topic.
