Fujifilm X-T3, 4K p60 internal video
  • 102 Replies sorted by
  • Lot of useful stuff
    LOG realization
    https://www.ixbt.com/dv/fujifilm-xt-3-cinema-review.html
    702 x 492 - 70K
    709 x 499 - 68K
    697 x 489 - 58K
    694 x 505 - 73K
  • Very helpful.
  • New v2.10 firmware
    • Recording over 4GB movie file as one file - Movie files are no longer split when the file reaches 4GB file size. The file is recorded as one file providing an SD memory card greater than 32GB is used (excludes 32GB). By using SD memory cards less than or equal to 32GB, movie recording will continue without interruption when the file size reaches 4GB, however subsequent footage will be recorded to a separate file. Note: Format SD memory cards before first use, and be sure to reformat all memory cards after using them in a computer or other device.
    • Fix of slight defects
    http://www.fujifilm.com/support/digital_cameras/software/firmware/x/xt3/index.html
  • Fujifilm has new upcoming firmware update for the X-T3 - v3.0. It'll come in April.
    Firmware 3.0 will further improve Eye-AF, will provide faster AF tracking performance and face detection. Face selection will be added, and 'touch operability' will also be improved.
  • New Firmware Updates for FUJIFILM X-T3
    New firmware version [FUJIFILM X-T3 Ver. 3.00] for the FUJIFILM X-T3 will be released in April 2019 to strengthen the accuracy of the X-T3's face/eye detection feature, and to provide enhanced AF performance and speed, and operability of the X-T3 touch screen.
    • Enhanced Accuracy of Face/Eye Detection and AF Performance: The X-T3 firmware update provides improvements in the X-T3's AF algorithm, with face detection of the X-T3 enhanced by approximately 30%. Additionally, the firmware serves to make the AF tracking even more stable not only in still photos but also in video recording.
    • New "Face Select" Function: The new X-T3 firmware update adds a new "Face Select" function to provide priority auto-focus, tracking, and exposure on a selected subject when multiple faces are detected within a frame. X-T3 users can make a selection via the touch screen or focus lever.
    • Fast AF Speed: The X-T3's new firmware update provides the camera with a new AF algorithm, which improves the AF speed from previous versions, regardless if the subject is located a short distance or farther away.
    • Intuitive Operability: The firmware update provides additional settings for the X-T3's touch screen that provide enhanced ease-of-use when focusing.
  • Sensor used in T-3 got Japanese Ministry Innovation Award
    760 x 593 - 124K
  • New low-contrast F-Log LUTs -
  • Meike MK-XT3 Pro Battery Grip
    • Working Voltage: 6.8V (grip) /3V (remote controller)
    • Working Temperature: 0 ~ 40°C
    • Applicable Battery (Not Included): NP-W126/NP-W126S (for grip) / 2 x AAA batteries (remote control)
    • Size: About 142x58x98 mm (grip) / 108x30x21mm (remote control)
    • Weight: approx. 265g (grip) /32g (remote control) (batteries not included)
    742 x 462 - 43K
  • Is the 20/30 min record limit lifted with the new firmware? I can see that they are at least not splitting files anymore. But I don't know if the record limit is battery life, or due to the European video camera tax?
  • Firmware v3.10 will be out soon, will add many remote control features (USB connection):
    • Starting and ending video recording
    • Adjusting exposure settings (exposure mode, shutter speed, aperture, ISO sensitivity, exposure compensation) for video recording
    • Making manual focus adjustments
    A further firmware update in January 2020, version 3.20 will bring autofocus enhancements:
    • Improving the tracking performance of the eye AF frame, making it easier to attain accurate autofocus on the eyes
    • Improving face-detection performance when there are faces of different sizes within the same frame, making it easier to attain accurate autofocus
    • Improving autofocus capability on a foreground subject even when there is a mixture of foreground and background subjects within a frame, causing the foreground subject to go out of focus, e.g. when shooting flowers against a busy background
  • PR on new firmwares
    FUJIFILM Corporation (President: Kenji Sukeno) plans to release a series of firmware updates for the FUJIFILM X-T3 (hereinafter "X-T3"), starting in mid-December 2019. The updates reflect requests of additional features and operability improvement, received from users of the X Series of mirrorless digital cameras.
    The upcoming update will enable controls for video recording from Gimbal / Drone via USB communications. You can combine the X-T3 with a Gimbal / Drone that supports this function to significantly broaden your shooting options. FUJIFILM is in communication with Shenzhen Gudsen Technology Co., Ltd.*, SZ DJI Technology Col, Ltd.** and ZHIYUN*** (listed in the alphabetical order) about their plan to release compatible products. Fujifilm also plans to deploy this function to the FUJIFILM X-T30 and other models. Further firmware updates in the future will bring autofocus enhancement and other improvements to the X-T3.
    Main features
    Firmware update for the X-T3, due to be released in December 2019
    Firmware version: FUJIFILM X-T3 (Ver. 3.10)
    Gimbal / Drone support
    This firmware adds the following function to complement the current support for still image shooting via USB communications:
    Firmware update for the X-T3, due to be released in January 2020
    Firmware version: FUJIFILM X-T3 (Ver. 3.20)
    1. Enhanced autofocus
    2. Capability to save up to 9,999 pictures in each folder
      • Until now, the number of pictures that can be saved in a folder on an SD card was limited to 999. This update will raise the limit by ten times to 9,999 pictures.
  • Firmware v3.10 released
    1. Gimbal / Drone support
    2. Fix of minor bugs.
    https://www.fujifilm.com/support/digital_cameras/software/firmware/x/xt3/index.html
  • Firmware v3.20 released
    Enhanced autofocus.
    • Improving the tracking performance of the eye AF frame, making it easier to attain accurate autofocus on the eyes.
    • Improving face-detection performance when there are faces of different sizes within the same frame, making it easier to attain accurate autofocus.
    • Improving autofocus capability on a foreground subject even when there is a mixture of foreground and background subjects within a AF frame, causing the foreground subject to go out of focus, e.g. when shooting flowers against a busy background.
    The phenomena below during a movie shooting are fixed
    • Focus hunting at the minimum aperture.
    • A black line can sometimes appear on the bottom of the center.
