Edifier S3000 Pro - new flagship speaker
    • Power output: R/L (Treble): 8W+8W RMS. R/L (mid-range and bass): 120W+120W RMS.
    • Frequency response: 38Hz-40KHz
    • THD + N (testing level): 0.3%
    • Signal to noise ratio: 85dBa
    • Input sensitivity: Line in – 600 ± 50 mV, Balance – 1000 ± 50 mV, OPT/COAX – 400 ± 50mFFs, Bluetooth – 450 ± 50mFFs, USB – 400 ± 50mFFs
    • Certified HiRes
    • 107 x 107mm Planar silk diaphragm tweeters
    • Bass drivers: 6.5” (179mm) aluminum alloy diaphragm bass unit
    • XMOS xCore200 interface supports USB audio bitrate up to 192KHz
    • Bluetooth V5.0 with Qualcomm®aptX HD decoding
    • High-efficiency Class D digital power amplification
    • XLR Balanced input and RCA line-in jack
    • Electronic crossovers and dynamic control based on DSP
  • 2 Replies sorted by
