ANDYCINE AL-360 RGB On Camera Video Light
    • Has 360 different colors changeable by twist the knob.
    • Memorize last settings.
    • 3200K-5700K Color Temp Adjust in white color mode
    • 10%-100% Brightness dimmable both in color mode and white color mode
    • 210 individual leds 84 white and 126 RGB
    • Sony NP-F970/770/550 Batteries
    • Cam work with DC power adapter - 8.4v 2A
    • 330g
    • Around $75 at https://www.amazon.com/dp/B07KWRG6K4
  • 20 Replies sorted by
  • I left a comment about NP-F batteries. It seems absolutely crazy/weird to say that a device that uses them is wrong for doing it. They are some of the cheapest, most popular, and useful batteries in the industry.
  • @MikeLinn
    Quite fun review.
    • It is very common not to have DC power source
    • Sony NP-F batteries are standard for such lights and monitors, Canon batteries are usually optional mount and around 10x more rare
    • Thing with clicks is overrated, it is either resistor with limits or such deal.
    • Issue with light not turning off happens only on external DC input (present in our review).
  • Thanks @tcarretti and @Vitaliy_Kiselev the curved LED from Lishuai dont have price yet and the Andycine AL-360 RGB its very cheap.
  • @Manu4Vendetta
    If you ask me - look for lights without diffused panel, and better still - look for narrow angles lights. If you want to light someone face most efficiently and for longer time. :-)
    if you want real diffused light check
    https://www.personal-view.com/talks/discussion/19452/nab-2018-lishuai-w5-and-w10-curved-led-lights/p1
    https://www.personal-view.com/talks/discussion/19487/nab-2018-fotodiox-curved-led-lights#Item_3
  • @Manu4Vendetta As long as you're not too far away from your subject I think it would work sufficiently for portrait stills. I'm not a photographer, but some of the video footage I've shot with this light looks really nice.
  • @tcarretti This light can work as key light for night portrait (still) if I want to work with continuous light?
  • Light spot
    800 x 476 - 79K
  • Flicker, 51% duty PWM, 15.6Khz
    800 x 672 - 104K
  • Thermals after temperature settled
    477 x 635 - 32K
    472 x 638 - 51K
  • ANDYCINE AL-360 RGB (Daylight 5700K setting), Measurement using CV600, Russian Lab processing
    Focus on TM30 and CIE 224 and look for color distortion and Rf values.
    ANDYCINE AL-360 is good light with light quality suitable for videos.
    Color temperature
    CRI color quality
    CQS color quality
    TLCI 2012
    TM30 color quality
    TM30 details
    CIE 224 2017
    800 x 424 - 32K
    800 x 401 - 52K
    706 x 515 - 55K
    708 x 432 - 55K
    800 x 484 - 63K
    800 x 331 - 47K
    456 x 457 - 30K
    800 x 273 - 66K
    800 x 422 - 48K
    502 x 505 - 44K
    792 x 374 - 40K
  • ANDYCINE AL-360 RGB (Tungsten 3200K setting), Measurement using CV600, Russian Lab processing
    ANDYCINE AL-360 is quite good light with light quality suitable for videos.
    Color temperature
    Note that light is badly calibrated with quite big difference from setting.
    CRI color quality
    CQS color quality
    TLCI 2012
    TM30 color quality
    TM30 details
    CIE 224 2017
    797 x 436 - 36K
    800 x 411 - 51K
    741 x 523 - 61K
    738 x 451 - 59K
    800 x 494 - 63K
    800 x 337 - 43K
    687 x 673 - 54K
    800 x 277 - 65K
    509 x 511 - 45K
    789 x 375 - 41K
    800 x 423 - 50K
  • RGB mode measurements
    Blue
    Green
    Red
    As you can see on CIE chart, colors are very good and saturated, so you can produce with easy much wider gamut than sRGB/Rec 709.
    798 x 419 - 30K
    430 x 485 - 54K
    797 x 420 - 33K
    452 x 481 - 53K
    799 x 415 - 31K
    460 x 480 - 54K
  • I got this about a week ago and am extremely happy with it. It's easy to use, pretty light for handheld work, and has good diffusion as well. The added hotshoe adapter is solid and allows for tilting which is another plus. I'm thinking about getting another one since it would make a great background accent light as well.
  • Internals photos
    Light has nice compact construction and knobs are fast and easy to adjust, screen is nice.
    Led panel is quite complex here, as it has 3 different kind of leds.
    Large ones are RGB, one warm and one cool white leds.
    Note how nice can see each PWM channel on controller board (R,G, B, Y is warm white, B is daylight white)
    Soldering is average, with few small areas with flux remains (I mean board parts, for wires it is usually ok).
    Other side of controller board with screen and knobs.
    Nice touch is alu radiator, despite that it is small and won't have much effect for leds located not underneath.
    800 x 634 - 105K
    800 x 487 - 63K
    758 x 610 - 55K
    800 x 635 - 117K
    800 x 423 - 57K
    800 x 483 - 107K
    800 x 598 - 93K
  • Light output change with time (as battery gets depleted)
    Not bad, as most of the time it can keep output.
    But ideally must be such:
    800 x 429 - 45K
