They officially have pro res now at 422 ..interesting little guy now
How about special PV Edition for less $$$ that can use hoverboard &c?
Z-Cam just linked to this youtube video:
Apparently some of the footage for the LED waterfall was shot with an array of E2's using their frame sync feature - the result was 30,000x20,000 pixels. That's pretty darn neat.
I'd guess that the reduced dynamic range comes from whatever cheaper sensor they are using. Judging by PoE as a feature, I'd also guess that they intend the cheaper camera to be used in multi-camera streaming setups which are frequently indoors where lighting is fairly easy to control.
In any case, a ProRes/raw capable camera available for $799 is still pretty great. There's pretty much 0 competition in that range - and if it doesn't sell well at $799, I'm sure the price will come down similar to the E1.
they are also going to release a budget version with a smaller body and reduced dynamic range and only 30fps for $799.
It must be $499, and idea to reduce dynamic range and such is very bad.
But it seems like my communication with them got real response.
Hmmmm. Wonder if the budget version could be hacked to shoot 4K 120?
Aside from the E2G which is pretty much ready, they are also going to release a budget version with a smaller body and reduced dynamic range and only 30fps for $799.
K30fps 10bit with all the codec E2 has + POE with USB type C and SD card as storage.
HDMI 4K30fps as well.
https://www.facebook.com/groups/zcame2/permalink/344850559579229/
Love that Toronto footage jleo <3
I “hacked” it, though it’s not much of a hack.
And yes, ProRes is latent in the firmware and just not enabled yet. And with the new beta firmware, they distribute as a pw protected zip file which makes it harder to find the trick.
I thought it's in the firmware but not yet "enabled" pending licences for pro res . Are you saying you hacked it to enable pro res ? Or did they already enable it ?
Judging by the fb group, measuring dynamic range on cameras is hard and depends on how one measures SNR
To be correct - measuring "dynamic range", first require to do proper definition of it. Including specified SNR.
And as almost 100% cameras have some kind of noise reduction you also need special measures to fully eliminate it's effect, show worst real case.
Z-Cam are claiming that the latest firmware beta has similar DR to an Alexa at up to 30p
As I see each day that Z-Cam guys are doing I want to cry. Now they want to compete with Alexa.
Company completely do not understand where camera must fit on the market.
This is the game they play now:
Judging by the fb group, measuring dynamic range on cameras is hard and depends on how one measures SNR. Z-Cam are claiming that the latest firmware beta has similar DR to an Alexa at up to 30p. I haven't done any tests with it yet, but even when I do, I don't have an Alexa to do side-by-side comparisons so that will be difficult to evaluate. It seems from the tests of others, though, that the new non-WDR mode has similar DR to the WDR mode and that's actually pretty exciting.
Is it possible to have 15 stop DN with this E2 ?
Correction - the new firmware beta adds ProRes Proxy and now ProRes 422 shows up as an option at 4kp60. I haven't tried it yet, but I'm excited!
@sammy Yes. It wasn't too hard to look around their firmware and figure it out. The first way I found was hard and would get reset every time you changed any of a number of settings. The second way I found is super easy and stays on. Since you seem to be following the group, you have probably seen me mention it there multiple times already.
And yes, it enables all flavors within the limits of what the camera supports - prores 422 and hq up to 30p and prores lt at up to 60p.
@Eastmoomuchjam you know how to enable prores on E2? And in all flavors ?
Mark has been working on the comparison for a while so that's also with a slightly older firmware version. I'm glad he finished it. The E2 footage is also with a slightly older firmware and h.265. When he has some time, I also expect that he'll do some ProRes tests since I gave him the trick for enabling it.
Z Cam E2 looks good in this comparison:
It keeps getting better .. the sensor now can do 16 stops and "magic" is not involved .per Facebook group
It is not magic it is engineering. The sensor is capable to do more than 15 stops. In fact when WDR is enabled it is 16 stops. As a professional camera manufacturer of course we have dynamic range test methodologies and tools not just test scenes.
So they decided to explain the magic behind the increased dynamic range from same sensor . Via Facebook group
I've seen a lot of "cloud reviewing" about dynamic range yesterday and let me give you some basic knowledge on log curves. When you understand how log curve compress lights you may find the way you use to judge dynamic range is kind of wrong.
Sensor dynamic range can be higher than camera system dynamic range. For example the sensor can be over 100db dynamic range but the adc is only 12bit which will limit it to maximum 13 stops. If the system only deals with 12bit raw in pipeline it will be maximum 13 stops too. For those who claim Arri can do 16 stops I just want to let you know it's impossible.
Log compress low light and highlights non-linearly. Normally if we normalize the light range, from 0.5-1 light range are compressed to less than 10% room. The beginning a few stops are very weak so if we don't put enough lift for these signals it will be enlarged hundreds times which will bring in very serious noise. So normally camera makers give 10%-20% of the light range as lift. This area is normally not log(we have a parameter of cut in log curve), so stops here are very flat. Then when you observe from scope the difference among these stops are weak.You can refer to existing DR test charts from log based cameras. So what to judge? SNR. I just want to say that the scene footage won't be easy to judge dynamic range from not proper prepared light environment. It's easier to judge by comparison. If you get Arri to shoot in the same condition you still have the same feeling. That's not your fault.
More stops in shadow means it's more clean with the same sensor and it also means that you can under expose and still get the details back. One problem we didn't design more stops to highlight is some of our customers don't have enough lighting experience and sometimes there are shadows in face and it will break the image if it's under exposed. Most of the users I talked to don't use false color as exposure tool and that means getting into problem is a sure thing. I DON'T care how other brands solve the problem but I DO care how to make our users easier to produce good image with less efforts and I don't want them to fail in shooting. We modified the AE strategy as well to prevent over exposure as well.
I haven’t been near my camera to try the new beta, but feedback from those who have tried it has been very positive.
