That video cant be true!...Canon is great!!!
I'm so sad about lack of IBIS. This would be my absolute perfect all purpose camera if it had it.
Bet the Fuji X-H2 will have all the goodness of the X-T3 plus IBIS
Here is a video I made on the Linear focusing. Linear focusing is some what useful but short of being great. I think it is a step forward but the lenses need better precision to be more useful so they don't drift as demonstrated.
FUJIFILM X-T3 Ver. 2.00 : December 2018
- 4K HDR video recording in Hybrid Log Gamma (HLG)
Supports 4K HDR video recording in the Hybrid Log Gamma (HLG), one of the formats defined in the ITU-R BT.2100 international standards *. It allows the capture of rich and realistic images in a scene where there is a huge gap between highlight and shadow, or subjects with high color saturation. Only compatible with H.265(HEVC). Please enjoy with television or display compatible with HLG formats.- Simultaneous output of Film Simulation and F-Log footage
Supports simultaneous output of Film Simulation and F-Log footage. It allows you to record in F-Log while checking Film Simulation image on an external monitor. Not compatible with 59.94P/50P, FHD high speed rec., 4K interframe NR, and HDMI output info display mode. Also, cannot choose different image size (4K/FHD) for HDMI output and internal SD card recording.- Recording over 4GB movie file as one file
Movie files are no longer split when the file reaches 4GB file size. The file is recorded as one file providing an SD memory card greater than 32GB is used (excludes 32GB) ***. By using SD memory cards less than or equal to 32GB, movie recording will continue without interruption when the file size reaches 4GB, however subsequent footage will be recorded to a separate file.- Display color temperature (Kelvin) on EVF/LCD
Color temperature (Kelvin) can be displayed on EVF/LCD.- Supports slower shutter speeds with DCI4K/4K 29.97P/25P/24P/23.98P *4
Slower shutter speeds than the framerate can be selected with 4K 29.97P/25P/24P/23.98P.
Cannot select slower shutter speed than framerate with DCI/4K 59.94P/50P or LongGOP recording.- Compatible with ALL-Intra and maximum bitrate 400Mbps with H.264
Using H.264 compression, you will now to be able to select ALL-Intra at a maximum bitrate of 400Mbps.- Display power supply icon
Power supply icon is displayed on EVF/LCD while using AC adapter (AC-9VS), or Anker PowerCore+ 26800 PD *5 and Anker PowerCore Speed 20000 PD
Anker and PowerCore are trademark or registered trademark of Anker Innovations Limited or associated companies. Product may not be available on your country.
FUJIFILM X-T3 Ver. 2.00 : Available
Power supply icon is displayed on EVF/LCD while using AC adapter (AC-9VS), or Anker PowerCore+ 26800 PD.
Note that large video files still not supported and this feature is postponed till sometimes in 2019.
http://www.fujifilm.com/support/digital_cameras/software/firmware/x/xt3/index.html
I have to say the color and sharpness are very good. Anyway at all around the time limit?
@DrDave None that I have heard. I plan on getting a Ninja V which would be one solution.
