Magewell Ultra Stream HDMI - Recorder and Streamer
  • 4 Replies sorted by
  • The downside is that the bitrate is limited to 4mbit.
    May be it is only streaming and mobile app one, do not know.
  • My understanding is that it will accept up to 4K 60 (4:2:0) input signals over HDMI, but will downscale to 1080p60 for recording.
    What is unclear from the specifications is what bitrate it records at. Only the resolutions seem to be listed and not what record bitrate is used at each resolution and frame rate.
  • @DrDave
    Yes, it records up to 1080p60
    It is mostly made for gamers. But can also work if you need to record some software.
  • It says support for 4K, but it does not appear to record 4K.
    HDMI Specific Features
    Support for up to 4096x2160 4:4:4/4:2:2 30fps or 4096x2160 4:2:0 60fps input and loopthrough signals
    Support for 8/10/12-bit color depths
    Support for 60p, 60i, 50p, 50i, 30p, 25p signal formats
    Analog Audio Features
    Extraction of stereo embedded HDMI audio for recording and output via 3.5mm stereo mini-jack Line Out
    Recording and streaming analog audio via 3.5 mm microphone interface
    Streaming Features
    Support for live streaming using RTMP protocol to software including Flash Media Server, Wowza, Red5 and Nginx server
    Streaming to Facebook, Twitch and YouTube platforms
    Support for streaming to 2 servers simultaneously
    Recording Features (to USB Flash Drive)
    Support for H.264 High Profile (video) and AAC High Quality (audio) encoding
    Supports recording at input signal resolution up to 2048x1080
    Support for 1920x1080, 1600x1200, 1440x1080, 1440x900, 1280x1024, 1280x960, 1280x800, 1280x720, 1200x900, 1024x768, 960x540, 800x600, 768x576, 720x576, 720x480, 640x480, 640x360, 480x360 resolutions
    Support for 60fps, 50fps, 30fps, 25fps, 24fps, 15fps frame rates
    Support for recording as MP4 files
    USB Flash Drive file system format: FAT32, NTFS, exFAT, VFAT
