New In RX 7 Advanced
Dialogue Contour - Ever wanted to change the intonation of a re-edited sequence? With RX 7 you can now reshape the intonation of dialogue to rescue or improve a performance, powered by pitch correction tailored to speech and designed to adjust the inflection of words within a phrase.
Dialogue De-reverb - iZotope has taken the excellent De-reverb module and produced a version designed to reduce or remove unwanted reverb from dialogue clips using a machine learning based algorithm trained to separate spoken dialogue from reverberant signal content.
Pro Tools AudioSuite plug-ins - iZotope has taken some of the processes that could only be used as modules in the standalone version of RX 6 and made them into Pro Tools AudioSuite plug-ins saving you time when fixing production audio by staying within Pro Tools to access features like De-Rustle and Dialogue Isolate.
Multi-channel support - It can now process audio issues that come up in any or every surround channel up to Dolby Atmos 7.1.2.
New In RX 7 Standard
Repair Assistant - iZotope has taken the ‘Assistant’ technology, which they have already introduced into Ozone and Neutron to produce what they claim to be an industry-first intelligent repair tool analyses audio to detect defects like noise, clipping and clicks, then offer three processing suggestions, each with three different intensities to help make fixes faster than ever.
Music Rebalance - Using a machine learning based algorithm, Music Rebalance performs source separation by identifying vocals, bass, percussion, and other instruments. You can then individually enhance or reduce elements of a stereo audio track, making it possible to adjust a mix when you don’t have access to the multitracks or stems.
Remove/Isolate Vocals - iZotope has designed it so you can take push the Music Rebalance module even further to create instrumental versions of songs by removing the vocal elements, or isolate the vocal to prepare a remix when you don’t have access to individual tracks or stems.
Long thing
Btw you can also see RX7 results in our IBC videos.
So to the useful stuff
