These are really great lenses.
Adobe Profile PR
Irix 11mm f/4.0 and Irix 15mm f/2.4 lenses: Now with official Adobe CC profile support
We would like to remind all current and future users of Irix lenses that as from June 19, the Adobe CC package is now officially supported for Irix 11mm f / 4.0 and Irix 15mm f / 2.4 lenses (from ACR 10.4) which allows automatic correction of distortion and chromatic aberration.
As one of the few manual lenses available on the market, Irix lenses are equipped with an electronic AE system which not only allows the user to control the aperture from the camera, but also to record information on exposure parameters in EXIF format, the effect of which is the possibility of continuous software development of our lenses.
We believe that photography should be a harmonious process, not a struggle.
Users of previous versions of Adobe software can still download the appropriate correction profiles from www.irixlens.com (http://en.irixlens.com/downloads).
Sony version coming
We plan to release lenses equipped with Sony E’s native mount in the near future. However, wo do not know when the first lens with E-mount will be ready for sale
Lens will be available in Nikon Z mount version soon. Cine version will be first but normal must follow.
15mm T2.6 Irix Cine lens
Available at https://storeeu.irixlens.com/en/
PR
Irix, the producer of the Cine series, currently has a set of cinematographic lenses in its portfolio, including an 11mm ultra wide-angle lens, a standard 45mm lens, and a 150mm macro telephoto lens. Today Irix premieres their fast, filter-ready wide-angle cine lens, the Irix Cine 15mm T2.6. This product will open unlimited possibilities for filmmakers and cinematographers alike.
New Lens, New Possibilities
The newest member of the family, the Irix Cine 15mm T2.6, is a fast, filter-ready ultra wide-angle lens, which makes it an extremely versatile piece of equipment that works in a multitude of lighting conditions.
The Irix Cine 15mm T2.6 optical system is made up of 15 elements arranged in 11 groups (including 3 HR lenses, 2 EDs, and 2 ASPs). Its precise construction ensures beautiful and vivid colors, image sharpness, and minimal distortion, despite the ultra-wide field of view. The high quality construction ensures low lens breathing, which is an extremely important feature in filmmaking.
Like all Irix Cine line lenses, it is designed for filming at a maximum resolution of 8K UHD, allowing for super-panorama shots (CinemaScope).
Irix Cine family
Ease of use and convenience is extremely important to us. Irix Cine lenses are ready for any film set. Very similar weights (as well as equal distances between rings) between Irix Cine lenses accelerate work on the set, without forcing changes of gimbals, rigs, tripods, etc. Irix also offers an innovative magnetic mounting system (MMS) for accessories, such as sun visors or lens covers.
Irix Cinematic Design
Irix lenses are used by both professional operators and amateurs alike. Irix Cine 15mm T2.6 has all the features and properties necessary to work on the set. By minimizing the phenomenon of diffraction, the lens' aperture (made of 9 rounded blades), provides a sharp image, regardless of the T value. The precise mechanics allow for the smooth adjustment of the T value from T2.6 to T22.
As with other Irix Cine lenses, the product has been equipped with an innovative adaptive ring that allows for ergonomic work both in manual sharpening and with follow-focus systems, thanks to which you can easily and quickly adjust your lens to your rig. The 180 degree focusing ring ensures precise alignment and a smooth focus pulling.
The lens front has been optimized to work with 95mm matte boxes. Toothed rings (Mod 0.8 M standard), ensure compatibility with most follow focus accessories and aperture adjustment available on the market.
Ready to work in any conditions!
With film lenses, it is extremely important that the equipment is suitable for work regardless of weather conditions. Irix Cine 15mm T2.6 has been sealed in four key places, so you can shoot in the desert and in full rain, meaning you can be sure that your equipment will remain safe.
Main features
- UltraHD 8K resolution
 - 43.3 mm imaging field (Full Frame)
 - Fast aperture T2.6
 - 86mm front filter thread
 - ultra wide angle imaging field
 - minimal distortion
 - compact and lightweight construction
 - very low lens breathing
 - sealed construction
 - 95mm front diameter
 - magnetic accessory mounting system (MMS)
 - Removable lens hood
 - compatible with follow focus systems
 - engraved markings filled withUV-reactive paint
 - adapter ring for faster work on the set
 - possibility of mounting an additional lens support foot
 Available mounts
Irix Cine 15mm T2.6 is available in Canon EF, Sony E, MFT, and PL mounts, each with either metric or imperial focus markings.
Pricing and availability
The lens will soon be available in a wide network of dealers available at: https://irixlens.com/dealers-l... and at https://storeeu.irixlens.com for 1195 Euro.
Used like new for $299
