GVB PL12 Thermals
Looks not bad, hottest place is inside main controller board.
GVB PL12 Inside
Light has simple and cheap design, but better than Aputure M9.
Wheel used here is much more handy for adjustments and will live longer.
Front led board has large vertical holes for inside ventilation.
Battery and strange empty space inside
manufacturer decided to put empty space with some little vent holes.
It is not much efficient and take lot of space from battery that could be larger.
Main board
Soldering is not top notch here. Plus board is unnecessary crowded.
Lot of space is left between board and battery to make proper design and to not have battery wires solder points so densely placed.
GVB PL12 PWM at 100% (battery at not full fresh charge)
You can see that controller dims leds even at 100%.
See above that controller can't keep output level.
PWM Frequency is 43,45Khz
GVB PL12 PWM at around 25% (battery at not full fresh charge)
More complete brightness during discharge, it is much brighter than Aputure M9
But same approach used by controller - more life but with cost of falling brightness.
Compare to M9
Better brightness due to more and larger leds used
GVB Gear GVBPL12 (Daylight model), Measurement using CV600, Russian Lab processing
Focus on TM30 and CIE 224 and look for color distortion and Rf values.
GVB Gear GVBPL12 is quite good light with light quality suitable for videos.
Light tends to be slightly cooler than 5500K.
Color temperature
CRI color quality
CQS color quality
TLCI 2012
TM30 color quality
TM30 details
CIE 224 2017
We'll do more measurements, but for now controller behavior looks little strange.
Like M9 it can't keep up output, but it also have sudden jumps.
This one do not know, sorry. They do not have dealer as it seems.
Any EU places to buy yet?
Measurements coming soon.
