I'm trying to figure out how to fix problem of footage having color shifting issues when importing h.265 file from NX1 in Davinci Resolve: See screenshot below
https://www.dropbox.com/s/ydzbv8pfthldynm/Screenshot%202018-06-10%2007.15.22.png?dl=0
Tried program you mentioned but just gives me black blank screen for exported file.
I won't to avoid doing a conversion if possible because h.265 plays smoothly on my system when editing so editing wouldn't be an issue for me except for color issues.
I bought a program called footage studio and for me it is too slow for converting footage and I have a modern GPU 1060 gtx.
As I told - try simpler approach with converter first.
How do I split the colour components red, green and blue and then move blue component on second node and then recombine? Do you have a video or could write up some instructions? I don't really have the highest expertise on nodes only a small amount of knowledge but I can follow instructions fairly well since I know where the nodes are located. I'm assuming I have to right click on first node to do separation just not sure what option and then hit alt+s to create a new node but not sure how to move blue component and on third node i.e. hit Alt+S for third node but not sure how to recombine them all together.
Try https://www.personal-view.com/talks/discussion/16945/as-video-converter-something-that-really-uses-hardware#Item_2 to export to H,264
On good modern GPU it'll be very fast conversion.
