Our full video review
Didn't know that the M9 would run off USB. That might make it usable for me as the built-in battery just won't sustain constant brightness for any length of time.
If you leave it plugged into USB and just turn it on it will eventually run dead even while plugged in.
Useful input, will need to add to such light tests list. They really need to slightly change controller board behavior. One of reasons can be that it requires more power for leds compared to M9.
One thing to note about the Sokani that has hit me while using it. It doesn't draw enough power (Appears to draw ~750mA max with several different chargers and cables) from the USB connection to maintain it's power level while it is on. If you leave it plugged into USB and just turn it on it will eventually run dead even while plugged in. I was using it for a multi-hour timelapse where I just needed a little video light and it went dead a ways in. There's also a minimum power level where it is plugged in and on but the light cannot be turned on. Once it charges some the light can be turned back on. However if you turn it on when it is already low on power, it will not run for very long before it turns off again. I've used the Aputure M9 a few times since for this and it will run continuously on USB power.
Thermal photos
Hottest part is board inside and OLED screen
Sokani X21 inside
Really nice construction with alu case, nice quality board, battery is 4.07WH and could be larger.
Board with leds
Vent holes are quite small.
Battery - not bad, but could be slightly larger capacity
Main board
Very nice soldering and overall quality and design.
Sokani PWM at around 50%
PWM Frequency is 10Khz
Sokani PWM at 100% (battery at not at full fresh charge)
You can see that controller drives leds at maximum always.
See above that controller CAN keep output level properly.
Sokani PWM at around 10%
@eatstoomuchjam That's good news. Sounds like plenty of fine tuning ability for most situations where you may need something this size.
@mee - 99 or 100, I suppose. The screen on the back shows the current power as a percentage (though I haven't tried going lower than 50% so it might not go all the way to 0 - and I wouldn't be surprised if the lights showed some flicker at lower percentages).
Spectrum and CRI
Sokani X21 (Daylight), Measurement using CV600, Russian Lab processing
Focus on TM30 and CIE 224 and look for color distortion and Rf values.
Sokani X21 is good light with light quality suitable for videos.
Color temperature
CRI color quality
CQS color quality
TLCI 2012
TM30 color quality
TM30 details
CIE 224 2017
Support us to see more info like this - https://www.patreon.com/personal_view
Have no idea, can send us one if you like to make test :-)
Well, having light that goes down so fast like Aputure is not good. As I said, I believe it was made intentionally to have longer life. As all good led controllers always keep up brightness until input is in defined margins.
Didn't know about the brightness dropoff over time. Does the GVBPL12 experience this? The Sokani is rated at only 50 mins which is shorter than both the GVB and Aputure, but I really do like that it comes with the color gels.
By idea, any led controller must be designed in such way.
Is that lux rating from 0.35m as well? Very nice results in consistency
And here is Sokani X21 - proper good behavior
note that initial small intensity drop is not due to controller, but due to leds heating up
Tried this with M9, here it is at 0.35m -
Will do with Sokani soon.
We'll add this to the tests list, thanks.
One bummer is that the included color gels aren't cut to a size that will fit in the carry pouch (the ones included with the other lights are). Not a big deal - I own scissors, but it would be a nice touch to have the filters fit better in the case.
Yep, you can see it on photos above. I'll tell manufacturer.
I just got the couple that I ordered.
Like the M9 and the little GVBGear, they are really bright! One bummer is that the included color gels aren't cut to a size that will fit in the carry pouch (the ones included with the other lights are). Not a big deal - I own scissors, but it would be a nice touch to have the filters fit better in the case.
Otherwise, I haven't had much of a chance to play - but I'm excited! I think they're the brightest of the bunch so far - at least, they hurt my eyes more than the other two. :)
So, fast preliminary testing
The Sokani X21 LED Video Light is a nicely built rechargeable light than is not expensive at $50. It is machined out of metal unlike a lot of other inexpensive lights which are made out of plastic or composites. It is light weight at 100 grams and comes with 2 magnetic filters. One is a diffuser filter and the other is a 3200k diffuser filter for the 21 daylight LED’s. It also comes with 12 color gels for sandwiching in-between the magnetic filters and the unit, a universal cold shoe mount, a USB charging cable and nice carrying case.
After charging, you turn on the light with the left side power switch by pressing in for 2 seconds. The OLED display on the back comes on and it displays the battery usage and brightness percentage. Hit the power button again on the LED’s come on. There are 2 buttons on the top to vary the brightness of the LED’s. Looking at the back, the left button is for lowering the brightness and the right one for increasing the brightness. Simple. There is a 1/4 inch thread for mounting on the cold shoe mount.
This light feel very durable and the magnets are a nice touch for mounting filters. Also it is very small because of built-in rechargeable batteries. A really nice little video light.
Alan's opinion
Package Includes:
