Best idea of you travel a lot and few funds can be ditch bmpcc and raw:-)
Go with H.264 or ProRes route and use any refurbished 4 core notebook with separate Nvidia GPU.
From new things (not within your budget) - https://www.personal-view.com/talks/discussion/17719/xiaomi-mi-notebook-pro-macbook-pro-competition#Item_13
Well, the Im trying to give the bmpcc a new lease in life and it would be perfect for this intended purpuse, small light, small lenses, great image. I dont need raw for this ofcourse I`ll be recording in prores LT most probably.
The suggested laptop I have already checked out, but it is too big. I have a sports bike, with small side bags and it needs to fit in there so it must be under 13" and even that is cuting it real close. I would use a phone to do this, but I don`t recall any apps being able to edit and grade prores.
OK, if it is Prores and H.264 only can look for 8550U based laptops.
Will be hard to find proper, as you need used or refurbished.
Normal Mac usable for editing is 2-3x of same Windows note. At least this was last time I checked.
You need to check if such Macs are good and will work as you want. I do not see much problem working with ProRes using Windows.
