Venus Laowa 9mm f/2.8 Zero-D Ultra Wide-Angle Prime Lens, $429
Laowa 9mm f/2.8 Zero-D provides an ultra wide-angle coverage up to 113° angle of view (100° on MFT system). The f/2.8 maximum aperture is well-suited to working in low and difficult lighting conditions. Also, 2 aspherical elements plus 3 extra-low dispersion elements successfully correct chromatic aberration, realize close-to-zero distortion & deliver excellent corner to corner sharpness. The tiny size (60 x 53mm) & lightweight (215g) encourages the photographer and videographer to use it every day and it is a perfect match for gimbal and drone.
New Mount: Nikon Z
Other mounts available: Sony E / Fuji X / Canon EF-M / L mount / MFT / DJI DL (Product Page: https://www.venuslens.net/product/9mm/ )
Laowa 9mm T2.9 Zero-D Cine
Laowa 9mm T2.9 Cine provides an ultra-wide-angle coverage up to 113° angle of view (100° on MFT system). The tiny size & light weight match perfectly with mirrorless cameras and are suitable for use with gimbals. The new Cine version comes with standard 0.8 mod gears on both aperture and focus rings. A standard 55mm filter thread is designed to mount screw-in filters easily. 2 aspherical elements plus 3 extra-low dispersion elements successfully correct chromatic aberration, realize close-to-zero distortion & deliver excellent corner to corner sharpness.
New Mount: Nikon Z / L mount
Other mounts available: Canon RF / Sony E / Fuji X / MFT
(Product Page: https://www.venuslens.net/product/0929cine/)
LAOWA 9mm f/2.8 Zero-D APS-C lens for Nikon Z mount
Venus Optics, the camera lenses manufacturer who had previously launched series of one-of-a-kind Laowa camera lenses, are proud to introduce the L mount to 2 wide angle lenses (4mm f/2.8 Fisheye, 9mm f/2.8 Zero-D) and 2 macro lenses (24mm f/14 2X Macro Probe, Laowa 25mm f/2.8 2.5-5X Ultra Macro).
- LAOWA 4mm f/2.8 Fisheye
- LAOWA 9mm f/2.8 Zero-D
- 24mm f/14 2X Macro Probe
- Laowa 25mm f/2.8 2.5-5X Ultra Macro
Venus Optics, the camera lenses manufacturer specialize in making unique camera lenses, unveiled three new ultra-wide cine lenses for cameras with different sensor sizes. They are the Laowa 7.5mm T2.1 Cine for Micro Four Thirds cameras, Laowa 9mm T2.9 Zero-D Cine for Super35 cameras and the Laowa 15mm T2.1 Zero-D Cine Lens for large format (full frame) cameras. All three lenses feature the same optical system as the their popular photography version and offer premium optical performance. They have also been built with robust cinema lenses housing with design up to the industry standard.
Ultra-wide FoV & fast aperture
All three Laowa cine lenses feature an ultra-wide angle of view and fast aperture. The Laowa 7.5mm T2.1 feature a 110° FoV on MFT while the 9mm T2.9 features a 113° on Super35 sensors. The 15mm T2.1 instead features a 110° FoV on cameras with full frame sensors. The fast maximum t-stop is well suited for filming under low light condition. It also allows filmmakers to have more flexibility in depth of field control.
Close-to-zero distortion
Both the 9mm and 15mm feature the distinguishing Laowa close-to-zero distortion (Zero-D) design where the optical distortion at infinity distance has been compressed to the minimal. This is extremely important for motion picture recording when shooting indoor, architecture or footage with straight lines included. This also saves tremendous amount of time in distortion correction in post processing.
Compact & lightweight
All three wide angle prime lenses are extremely compact and lightweight. Both 7.5mm and 9mm weigh close to 0.5 lbs (226g). The 15mm is a little bit heavier due to the larger coverage but Venus Optics still manage to compress it to around 1.2 lbs (540g). On the contrary to the huge and heavy wide angle lenses in the market, the new Laowa cine lenses are extremely handy for run-and-gun productions, shooting with gimbals, in-car shots, indoor scene, etc.
Close Focusing Distance
All three Laowa cine lenses possess an extremely close focusing distance. This provides a great deal of flexibility for directors to compose shots at any distance. Filmmakers can also take advantage of this close focusing to create some wide angle shots with shallower depth of field. Both the Laowa 7.5mm and 9mm can focus as close as 4.7" (12cm) from sensor to subject while the 15mm can focus up to 5.9" (15cm).
Industry standard cinema lens housing
The major difference between the new cinema version and the still version is the improved housing. The new cinema lens housing have been designed with details to facilitate filmmakers to shoot with ease. Both the aperture and focus rings have been built with industry standard 0.8 mod pitch gears for pairing up with follow-focus motors. The aperture ring is now click-less for smooth iris control. Every one of Laowa cine lenses comes with a filter thread for filmmakers to use screw-in filters and mini matte-boxes. Entire lens body is made by premium grade aluminum and build for usage in extreme environment.
Hassel-free transportation
An authentic hard case made by Pelican will be included with the lens to allow filmmakers to travel around for shooting with ease.
A variety of Current & Future mount options
The Laowa 7.5mm T2.1 Cine is available in Micro Four Thirds mount and it is a perfect companion to cameras like Blackmagic Pocket 4K, Panasonic GH5 and Z-Cam E2
The 9mm T2.9 Zero-D Cine is available in Fuji X, Sony E mount and Micro Four Thirds mount. The Micro Four Thirds mount can cover the same cameras as 7.5mm and serve as an not-as-wide alternative to MFT users. The Fuji X mount is extremely popular among XT-4 or XH-1 shooters. The Sony E mount works really well with Sony cameras with Super35 sensors including FS5, FS7, A6500 series, etc.
The 15mm T2.1 Zero-D Cine is designed for large format sensor with Sony FE mount available. It is best suited with Sony full frame cameras like Sony A7 series and FX9.
New Nikon Z, Canon RF and Leica L mount will be introduced later this year and they will certain be interesting wide angle options for cameras like RED Komodo, Canon R5, Nikon Z6/Z7, Sigma FP, Panasonic S1H and more to come.
Laowa Wide Angle Cine Lenses line-up
Together with the Laowa 12mm T2.9 Zero-D Cine released earlier for EF and PL cinema cameras, Venus Optics currently offer four wide angle cine lenses for cinema cameras with different sensor sizes.
Pricing & Availability
All three cine lenses are currently available to purchase via Venus Optics official website (http://www.venuslens.net/) and authorized resellers. The US price for 7.5mm T2.1 and 9mm T2.9 is $599/pc (ex-VAT) and 15mm T2.1 is $1,199/pc (ex-VAT). Pricing varies in different countries.
LAOWA 9mm T2.9 Zero-D Cine
Interview about m43 version
PR
Venus Optics unveil the new Micro Four Thirds variant for Laowa 9mm f/2.8 Zero-D
Featuring a 100-degree field of view and close-to-zero distortion & affordable pricing, Laowa 9mm f/2.8 Zero-D is a perfect lens for videography.
Anhui China, 3 Apr 2019 – Venus Optics, the camera lenses manufacturer who had previously launched a number of unique Laowa camera lenses, is proud to introduce the new Micro Four Thirds (M43) variant of the Laowa 9mm f/2.8 Zero-D lens. The new 9mm f/2.8 Zero-D lens provides a more natural perspective for videography purposes.
Similar to the Laowa 7.5mm f/2 MFT, another ultra-wide angle lens from Laowa, the 9mm f/2.8 features an ultra-compact body with an exceptional optics quality. It also provides a much more natural perspective for Panasonic GH5 or Blackmagic Pocket Camera (BMPCC4k) shooters to create impressive videos. The lightweight design & 100° angle of view also empower videographers to do vlogging and record with gimbals.
The new M43 variant has the same specifications and optical performance as the existing Fuji X, Sony E, Canon EF-M and DJI DL mounts. All of them feature an ultra-wide 113° angle, cover Super35-sized sensor and have a close-to-zero distortion. The Laowa 9mm is significantly wider than most wide-angle rectilinear lenses in the market. The ultra-fast f/2.8 aperture also provide more flexibility for both photography & videography purposes.
The lens is carefully designed to reduce the optical distortion to a close-to-zero level. It allows straight lines to be perfectly retained and saves videographers tremendous time in post-processing. Venus Optics is reputable in producing distortion-free lenses for multiple systems including the widest f/2 lens for full frame E-mount cameras (i.e. Laowa 15mm f/2 FE Zero-D).
The size and weight of the lens have also been compressed to the minimal in its class. It weighs only 210g (0.46 lbs) and 60mm (2.36 in) long. This compact and lightweight lens comprises of 15 elements in 10 groups with 2 pcs of aspherical elements and 3 pcs of Extra-low dispersion elements. This optical design successfully minimizes the distortion and chromatic aberrations to its lowest but at the same time, delivers a superb optical performance. A 49mm filter thread is also included for cinematographers to use with ND filters.
The lens will make its US debut in the coming NAB show in Las Vegas between 6-11 Apr in Venus Optics Booth (C11738).
m43 version preorder available
https://www.bhphotovideo.com/c/product/1467155-REG/venus_optics_ve928mft_laowa_9mm_f_2_8_zero_d.html
m43 version coming soon
Review
Both center and corner sharpness are impressively high wide-open at f/2.8 and outstanding between f/4-f/8. At f/11 sharpness starts to fall off a little, becoming progressively worse at f/16-f/22.
https://www.photographyblog.com/reviews/laowa_9mm_f2_8_zero_d_review/
Samples
https://www.dpreview.com/samples/5752696853/venus-optics-laowa-9mm-f2-8-zero-d-sample-gallery
PR
Venus Optics, the camera lenses manufacturer who had previously launched a number of unique Laowa camera lenses, is proud to announce the world’s widest rectilinear f/2.8 lens for mirrorless APS-C cameras, Laowa 9mm f/2.8 Zero- D.
Laowa 9mm f/2.8 Zero-D is the third member of the Laowa ‘Zero-D’ line-up and they all feature an excellent control of the optical distortion which is commonly appeared in ultra- wide angle lenses. This new lens is an ultra-wide & ultra-fast prime lens with a 35mm equivalent focal length of around 13mm. Despite the extreme specifications, Venus Optics has successfully minimized the weight of the lens to less than 0.5 pounds (215g) and 2-inch (53mm) long. This compact and light lens comprises of 15 elements in 10 groups with 2 pcs of aspherical elements and 3 pcs of Extra-low dispersion elements. This optical design successfully minimizes the distortion and chromatic aberrations to its lowest but at the same time, delivers a superb optical performance from corners to corners.
The extreme 113° angle of view and ultra-fast f/2.8 aperture allows photographers to create impressive astro-photography shots with ease. It also gives photographers a fast and wide-angle option for landscape photography and low-light shooting. For videographers, the compact size of this lens is friendly to the use of gimbals or even handheld shooting without much of shaking. The lens is designed with a 49mm filter thread which gives additional portability for screw-in filters. It comes with both Sony E, Fuji X & EOS-M mounts.
Availability
The Laowa 9mm f/2.8 Zero-D is currently available to pre-order in the official website of Venus Optics (http://www.venuslens.net/) and their authorized resellers. Recommended Retail Price in US (without tax) is USD 499/pc. Pricing may vary in different countries.
The first 100 orders will get a set of Laowa 49mm filters for FREE (CPL + UV + ND1000). Shipping is expected to start from early April.
