Specifications
UK PR
February 22, 2018, Saitama, Japan - Tamron Co., Ltd. announces the development of a new high-speed standard zoom lens for 35mm full-frame mirrorless cameras, the 28-75mm F/2.8 Di III RXD. This signals Tamron's plans to further expand and improve its lens lineup for 35mm full-frame mirrorless cameras, in addition to its lenses for DSLR and other mirrorless camera formats.
This new lens delivers superb optical performance, including both outstanding image quality and beautiful background blur effects (bokeh). Photographers will enjoy dynamic wide-angle expressions like never before thanks to a minimum object distance of 0.19 m at the wide-angle zoom setting. Usefulness and versatility are enhanced by its compact size and light weight, measuring only 117.8mm and weighing 550g.
The lens incorporates an all-new high-speed and precise RXD AF driving system. The RXD (Rapid eXtra-silent stepping Drive), stepping motor unit, operates with remarkable quietness, making it perfect for video use. The lens also features Moisture-Resistant Construction that is helpful in outdoor photography, plus hydrophobic Fluorine Coating that is highly resistant to fingerprints and debris. In addition the lens is compatible with the "Direct Manual Focus (DMF)" system feature of Sony cameras, enabling this new zoom to take full advantage of the advanced functions that ensure comfortable user experiences.
Main features
- Superb optical performance, including both outstanding image quality and beautiful background blur effects (bokeh), provided by fast F/2.8 aperture.
- Comfortably light weight (550g) and compact (117.8mm).
- Close-focusing; Minimum Object Distance: 0.19m at wide-angle setting and 0.39m at the telephoto position.
- All-new "RXD" stepping motor AF unit is extremely quiet and therefore perfect for video capture.
- Exciting next-generation design keeping the brand consistency that is ergonomically superb.
- Moisture-Resistant Construction and Fluorine Coating for weather protection.
- Compatible with the "Direct Manual Focus (DMF)" feature that enables Sony cameras to instantly switch between autofocus and manual focus.
Specifications, appearance, functionality, etc. are subject to change without prior notice.
Suggested Retail Price TBA
Availability from mid 2018
Our in depth interview
Chinese price (can be wrong) stated as ¥5300.00 that is $837.
Regardless of the protestations of the Tamron rep above, this sounds a lot like an updated version of the Tamron SP 28-75mm F/2.8 XR Di, equipped with a new internal auto-focus mechanism and a Sony E-mount. Check out the specs of the older lens in the link below. As Tamron has recently released similar-looking updates of their 24-70mm f2.8 and 70-200mm f2.8 zooms, this would appear to fit snugly within that roadmap.
Preorder is expected to start at April 27.
Price can be $799.
https://www.bhphotovideo.com/c/product/1393332-REG/tamron_a036_28_75mm_f_2_8_di_iii.html
Japanese strange rumors set price at 94,500 YEN
PR
April 27, 2018, Saitama, Japan–Tamron Co., Ltd. (President & CEO: Shiro Ajisaka), a leading manufacturer of optics for diverse applications, announces the launch of a high-speed standard zoom lens for Sony E-mount, 35mm full-frame mirrorless cameras, the 28-75mm F/2.8 Di III RXD (Model A036).
This new zoom lens delivers superb optical performance, including both outstanding image quality and beautiful background blur effects (bokeh) only possible with a fast aperture, thanks to a new optical system designed specifically for mirrorless cameras. In addition to shooting portraits with creative, defocused backgrounds, photographers can enjoy dynamic wide-angle expressions like never before thanks to a Minimum Object Distance (MOD) of 0.19m (7.5 in) at the wide-angle zoom setting. The usefulness and versatility inherent in compact full-frame mirrorless cameras are enhanced by the A036’s compact size and lightweight, measuring only 117.8mm (4.6 in) and weighing 550g (19.4 oz). The Model A036 incorporates an all-new high-speed and precise AF driving system. The RXD (Rapid eXtra-silent stepping Drive) strikes a balance between speed and silent operation, making it perfect for both video and still image capture. The lens also features Moisture-Resistant Construction that is useful in outdoor photography, plus hydrophobic Fluorine Coating that is highly resistant to fingerprints and dirt. In addition, the Model A036 will fully match with various camera-specific features including the in-camera lens correction and Direct Manual Focus (DMF) system features of Sony cameras, enabling this new zoom to take full advantage of the advanced functions that ensure comfortable user experiences.
Superb optical performance, including both outstanding image quality and the beautiful background blur effects (bokeh) provided by a fast F/2.8 aperture The Model A036 features a new design that leverages the advanced image quality of the latest full-frame mirrorless cameras. To balance beautiful bokeh with high image quality, the optical formula (15 elements in 12 groups) includes a special XLD (eXtra Low Dispersion) element, LD (Low Dispersion) element, GM (Glass Molded Aspherical) element and two hybrid aspherical lens elements in the optimal arrangement to correct aberrations and reduce the overall lens size. The lens also employs Tamron’s BBAR (Broad-Band Anti-Reflection) Coating that boasts exceptional anti-reflection performance throughout the entire zoom range, even when shooting in backlit conditions. In addition, incorporating the nine-blade circular diaphragm design, the lens will perform in versatile situation, providing beautiful soft portrayal at wide open aperture to a clear and sharp image when stopped down.
Comfortably lightweight (550g / 19.4 oz) and compact (117.8mm / 4.6 in)
Extra emphasis was placed on creating a high speed, fast aperture zoom lens in a compact and lightweight design because standard-range zooms are generally the most frequently used. Weighing only 550g (19.4 oz) with a length of just 117.8mm (4.6 in), the A036 enables photographers to enjoy the mobility provided by a compact, lightweight, full-frame mirrorless camera in all situations from casual snapshots to stunning portraits and dramatic landscape photography.Minimum Object Distance (MOD) 0.19m (7.5 in); Working Distance 5.7cm (2.24 in)
The Model A036 breaks from the convention that the MOD of a zoom lens must be fixed throughout the focal range and achieves a MOD of 0.19m (7.5 in) at the 28mm wide-angle end which delivers a maximum image magnification of 1:2.9. The working distance of just 5.7cm (2.24 in) from the front element allows photographers to enjoy close-up shooting that emphasizes the sense of perspective unique to wide angles. At the 75mm telephoto end, the 0.39m (15.3 in) MOD provides an image magnification of 1:4, thereby enabling close-up shooting with a pleasantly blurred background similar to a macro lens.All-new “RXD” stepping motor AF unit is excellently quiet and therefore perfect for video capture
The AF drive incorporates a sensor that accurately detects the position of the lens and an RXD (Rapid eXtra-silent stepping Drive) stepping motor unit optimized for AF control. This achieves quick and precise AF operation, allowing users to maintain pin-sharp focus on continually moving subjects or when filming video. Additionally, the AF motor is exceedingly quiet, virtually eliminating extraneous AF drive sounds during video recording.Consistent with Tamron’s exciting, ergonomically superb next-generation design
The Model A036 features a mirrorless-oriented design that adheres to Tamron’s new “Human Touch” lens design concept. As signified by the Luminous Gold brand ring, careful attention to detail has produced an optimum shape reflecting the characteristic look of a Tamron-branded lens, whether on its own or attached to a camera body. This design emphasizes consistent brand identity combined with ease of operation.Moisture-Resistant Construction and Fluorine Coating for weather protection
Environmental seals are located at the lens mount area and other critical locations to prevent infiltration of moisture and/or rain drops and afford Moisture-Resistant Construction. This feature provides an additional layer of protection when shooting outdoors under adverse weather conditions. Also, the front surface of the lens element is coated with a protective fluorine compound that has excellent water-and oil-repellant qualities. The lens surface is easier to wipe clean and is less vulnerable to the damaging effects of dirt, moisture or oily fingerprints, allowing for much easier maintenance.Compatible with main camera-specific features and functions Tamron’s new 28-75mm zoom is compatible with many of the advanced features that are specific to certain mirrorless cameras.
This includes the following:
- Fast Hybrid AF
- Eye AF
- Direct Manual Focus (DMF)
- In-camera lens correction (shading, chromatic aberration, distortion)
- Camera-based lens unit firmware updates
Preorders places, start later today
Finally.
Samples from Tamron
Some AF tests
Full size samples
Tamron issues statement that they can't keep up with preorders.
It became standard industry trick for good products.
Short overview-review with not full res samples
