50mm T2.1 SLR Magic APO HyperPrime CINE Lens
    SLR Magic will present a new CINE lens to the public from the APO-HyperPrime lens family in the upcoming Photokina 2014 fair in Cologne at the SLR Magic booth (Hall 5.1, L-011).
    The SLR Magic APO-HyperPrime CINE 50mm T2.1 is the first lens of the family. It achieves outstanding images under challenging lighting conditions.
    When taking pictures with many image-dominant, open light sources, it is common for correction defects to show up. However, because the SLR Magic APO-HyperPrime CINE 50mm T2.1 is an apochromatic (APO) lens, longitudinal chromatic aberrations are corrected by its unique optical design and selection of optical elements. The colour defects are therefore significantly lower than the defined limits. Bright / dark transitions in the image, and especially highlights, are rendered with no colourful artifacts. Thanks to the low level of longitudinal chromatic aberration, there are no visible aberrations. So an illuminated portrait scene by night with many light sources in front of and behind the actual focal plane appears close to reality, without displaying complementary, colour contrast edges.
    The superior performance delivered by the SLR Magic APO-HyperPrime CINE 50mm T2.1 is consistent for all shooting distances. Its high performance with an open aperture also makes this lens a great choice for portraits or close-ups.
    Features a completely new optical and mechanical design, which has been developed to take into account the special and increasing demands of high-resolution cameras including those with 4K and 6K sensors.
    The APO-HyperPrime CINE lens series comes standard in PL mount and can be easily adapted to numerous camera systems. Optional mount adapters will include PL-mFT adapter, PL-E adapter, and EF mount conversion adapter. The lenses all feature a standard focus rotation angle of 300 degrees and uniform measurements. This combination makes the lenses ideally suited for professional cinematography.
    As a continued dedication to anamorphic lenses, some of the lenses in the APO-HyperPrime CINE lens family would be compatible with the SLR Magic 1.33x 50 Anamorphot adapter.
    SLR Magic plans to exhibit the first lens of its PL cinema series at the Photokina, Cologne 16th to 21st September 2014. The SLR Magic stand is located in Hall 5.1, Booth L-011.
    SLR Magic will start shipping the APO-HyperPrime CINE 50mm T2.1 in early 2015.
  • 22 Replies sorted by
  • Our NAB interview
  • Here's a little update Andrew from SLR Magic has allowed me to share. I want to share as much as I can remember from my phone call with Andrew so hopefully it's relevant to those of you who are interested in these lenses.
    For anyone going to NAB, Andrew will have a booth and will be there. I invite anyone interested in these lenses to go see them. Andrew is a very knowledgeable and open guy and he really love to talk lenses. He cares about his products and making them the best they can be. They have some pretty cool announcements for NAB, whcih I won't share, but he's what I can...
    Here's a picture of a pre-production 32mm lens.
    www.flickr.com/photos/johnbrawley/40047075535
    I haven't shot with this copy yet, but this means SLR Magic are very close to going into production with this lens. After this they're working on the 18mm and the 135mm to fill out the set.
    I also received an updated version of the 25mm to replace my copy. It developed an issue with the focus bumping sometimes at close focus and Andrew tells me he's totally updated the helicoil design and has already updated a few customers copies. Anyone who sees this issue should be able to arrange to have it fixed. I didn't want to let go of my 25mm as I was in the middle of a job so he's sent me a second one and I'm now sending mine back.
    I also recently did a blind test of CP2's, Panavision Primos and the SLR Magic APO's.
    Watch the below link and don't read the description if you want to guess which is which and which you like.
    You can see this little bump in this video. The first lens, the "A" is the SLR Magic 25mm.
    What's cool is that SLR Magic went and immediately addressed the issue and have re-designed the lens to make sure it doesn't happen again. I've just finished a 6 month TV series using them day in and day out and this has been the only issue with them, even though they've been on prestons / motors with clamp on's all this time.
    Here's a couple of clips all shot with SLR Magic lenses.
    (everything except a couple of super macro shots in the last clip which were Cp2 50mm macro)
    www.flickr.com/photos/johnbrawley/40047076045
    Andrew also sent me copies of their new E mount, MFT and EF adaptors.
    www.flickr.com/photos/johnbrawley/40941422171 www.flickr.com/photos/johnbrawley/40047075035
    This means you can use your APO primes on any of the above mounts and with the SLR Magic adaptors they've kept the tolerances very tight so the witness marks should line up perfectly without having to actually re-shim the mounts / lenses, though you can do that if you need to.
    As a bit of a surprise, Andrew also sent me some brand new ND filters that he's been working on.
    Many would already be familiar with the Variable ND's they make, which many rate as one of the best made and offering very good IR protection as well. Some of you may know I shoot a lot of MFT lenses on Olympus, DJI and Blackmagic MFT cameras so I use a lot of smaller lenses with screw in ND's.
    Lately I've mostly been using the Hoya / Kenko PRO screw in ND's as they seem the most neutral. Andrew tells me he decided to make these after he decided to buy some Hoya Pros for his own work and was firstly forced to buy them from three different countries because no one stocked the full set and he THEN found that the deeper stop copies had more than 2/3 of a stop variation in exposure from where they should be.
    Well SLR Magic have done their own take on ND filters. They've aimed to be less than 1/3 of a stop variation and to sell them together as full sets.
    They make a set of N3, N6, N9, N1.2 and N1.5 (1-5 stops) and a second box of N1.8, N2.1, N2.4, N2.7 and N3.0 (6-10 stops) and each set is only $399. Pretty decent deal.
    I don't want to come off as a shrill, but I really like what these guys are doing and I especially like how responsive they are to feedback from us that use these lenses. In lieu of them having better marketing I'll try to let as many know as I can about what they're up to.
    JB
  • Way smaller than the Sony CineAltas (which I see as the main other competition in the low low budget PL lens category).
  • Hello @Maxr,
    Sorry here's the C1 file
    https://flic.kr/p/qXpAK8
    All good, like you say personal taste...
    jb
  • I was absolutely blown away, how the holly duck did he nailed same... everything in both engines, C1 and PS?
    Then I looked at the exif, both the photos in flickr are from photoshop.
    Doesn't really matter 'cause your version is way more "natural".
    Personally I was not after that natural look or any look in particular, just playing around with your footage. I end up going different ways with the orf and the grade; anyway I did already admit 3 times my grade is too goldfinger, it is from mistakes and many trial-error that one learns... poor Maddy that suffered my experimentation and thank you John once again for sharing.
    I'm out as I feel I have nothing else useful for the thread, cheeeeers fisusz
  • I think you can still have sharp without the need to use any sharpening.
    These are both from C1 and PS as default with the default sharpening turned down.
    http://flic.kr/p/qEtD5q
    And
    http://flic.kr/p/q14aLj
    It might also be your grade that is adding to that harsher more "processed" look ? And the debayer ?
  • Hey @johnbrawley
    Couple of things. The DNG's are grabbed from a clip of hundreds of DNGs that went though the same focus pulling regime as the ProRes files... It depends on which point in the sequence I grab as to how much is in focus I suspect...I could load the DNG's I spose, but it would be a lot more than 15Gb !
    Of course, but we shall agree that it is what I had to compare with =)
    I think anyone with a pair of eyes can see it is very very sharp at T4
    It's also not unusual for lens makers to LIE about their stops to make them seem to perform better usually their wide open values.... Focal length can vary as well. A less than 1/3 stop variation doesn't surprise me.
    that would explain the smallish exposure variation
    I preferred the warmed look of the APO, as I like it for skin tones and I also tend to light warm.
    I preferrer it too... even with other more neutral hues, that's why it's so surprising I liked better the CP2 while grading, probably didn't look "hard enough", he he - I must admit I have a (retinal) tendency to like cooler palettes though
    I also think you over-sharpened poor Maddy in her final result but maybe you're looking for sharpness....?
    John, it is way too contrasty I agree but regarding sharpness in video, I didn't add any, zero whatsoever.
    The still (_1220443.orf) I developed with a touch of sharpness and micro contrast (not that it needed it), grab below. Also the downsizing C3C algorithm might have introduce some. -- I uploaded an unscaled (zero sharpness), Q&D developed version vs previous.
    With the video ... maybe 'cause *contrast separation* (???)... as a matter of fact I did blur her skin a little bit, as I felt it started to get ultrahd unflattering
    The SLR Magic 50mm T2.1 APO HyperPrime cine lens rocks, no doubt about that; cheers John
    2135 x 742 - 1M
  • Hello @maxr.
    Or in other words, does it gather more light os is one at T4 and one not ?
    It could also be something to do with flaring. I deliberately added a bare Kino tube in shot to test for veiling flare. It may well be that one lens is flaring more than the other, which causes the overall exposure to shift.
    I preferred the warmed look of the APO, as I like it for skin tones and I also tend to light warm. And again, it's not unusual for lenses to be of a different colour. The Cookes and the Panavision Primos are also well known for a warmer look...I'd say it's in pretty good company....
    JB
  • Hey @johnbrawley we're splitting hairs here, he he he. I took a look at the dng's and now I am even more confused.
    When I was playing with the proRES I kind of liked the overall look (colour rendition wise) of the zeiss better. Checking those dngs (Blackmagic URSA_1_2015-01-22_1605_C0006_000587 and Blackmagic URSA_1_2015-01-22_1558_C0001_000608 for example) it seems the SLR magic's test dng is focused very slightly further back and that the zeiss managed to gather more light. But the confusing thing is not that as both lenses are plenty sharp, the confusing thing is that after levelling the exposure (-0.2 exp on the zeiss) it is quite clear that the zeiss rendered a distinct blueish veil. Would be interesting to see how both lenses behave under different temperatures and lighting environments.
    Anyway merit where merit is due, you're right John, the SLR Magic seems a stellar lens =)
  • Hello @MaxR
    I think the really interesting is to look at the evry fine detail in the DNG's and compare the Zeiss to the APO. You'll notice on very fine detail like the fine hairs on Maddy's camera right shoulder and underarm aren't resolved as well or at all by the zeiss....
    This is a stellar lens I think for the money.....
    JB
  • @johnbrawley thanks for sharing the tests (15 GB!!!) and the light setup John. Very nice lens indeed... as it is the Zeiss, which (if only from these very good lit tests) I think I like more... for videoing at least. Very sharp yet smooth image from Ursa, a joy to tinker with. I matched the footage (with datacolor sample) and then graded it... a bit too gold and contrasty but I'm still diving into DR. Very cute Maddy (like a replacement goddess) with her tongue pushing the teeth =)
    SOUNDTRACK
    Cyndi Lauper's - Girls Just Wanna Have Fun cover
    Postmodern Jukebox // tweaked and squashed for fun
    https://www.youtube.com/user/ScottBradleeLovesYa/videos
    The Band:
    Robyn Adele Anderson - vocals http://www.facebook.com/robynadeleand
    Seth Paris - clarinet
    Nick Finzer - trombone http://nickfinzermusic.com
    Adam Kubota - bass http://www.facebook.com/adamkubotabass
    Allan Mednard - drums http://www.twitter.com/allanmednard
    Scott Bradlee - piano http://www.facebook.com/scottbradleem
    and the still, separately developed with Raw Photo Processor (composited in PS) from your MSLR's orfs and used as the video poster frame in YT, very compressed jpeg. Both Video and image are 3840x2160 - should see the tif and proRES. HAPPY LOSAR!!!
    3840 x 2160 - 2M
  • Here's a little update on the development of lens and it's price structure. When Andrew was in the US last spring, he spent some time with Roger C of LensRentals testing the original prototype. While it showed great results (as mentioned I played with it briefly and yes it was good) Andrew felt it needed to be improved. When he subsequently met John Brawley in Australia, based on the feedback there (the need for witness marks, 300 degree focus rotation, a focus ring shield) a second prototype was developed and shown at Photokina with a slightly increased price. That prototype had an aluminum PL mount and when concerns were voiced about its durability, the design was changed to a titanium mount. This is why the price of a fully specified cinema lens along with the apochromatic nature of the optics with first class IQ is a bargain, IMHO.
  • @mrbill "What stated price range? Website says price as yet unconfirmed.."
    When I spoke to Andrew earlier last year he threw out a figure that I told him was insane (low). JB states on his blog that the price is now $2k. That makes more sense given what the lens does but at that price it's still a bargain.
  • Just an update on this lens,
    I've shot some downloadable files with skin tones and also comparing the the Zeiss CP 50mm as well. There are DNG stills, as well as 4K ProRes 4444 files from URSA
    In my view this lens is really very good and just needs to be rounded out with a full set in other focal lengths ! Feel free to download here, and I'd love to hear your thoughts and what kinds of difference you see...
    https://johnbrawley.wordpress.com/2015/01/23/50mm-lenses-compared-plus-4444-prores-for-the-ursa/
    JB
    642 x 637 - 63K
    644 x 644 - 62K
  • What stated price range? Website says price as yet unconfirmed..
  • Played with a pre-production sample briefly earlier this year on a GH4 and Sony A7. One word....spectacular. And if the then stated price range holds, this is a home run....
