Microsoft: Bug fixing will cause significant speed decrease
  • Here is the summary of what we have found so far:
    • With Windows 10 on newer silicon (2016-era PCs with Skylake, Kabylake or newer CPU), benchmarks show single-digit slowdowns, but we don’t expect most users to notice a change because these percentages are reflected in milliseconds.
    • With Windows 10 on older silicon (2015-era PCs with Haswell or older CPU), some benchmarks show more significant slowdowns, and we expect that some users will notice a decrease in system performance.
    • With Windows 8 and Windows 7 on older silicon (2015-era PCs with Haswell or older CPU), we expect most users to notice a decrease in system performance.
    • Windows Server on any silicon, especially in any IO-intensive application, shows a more significant performance impact when you enable the mitigations to isolate untrusted code within a Windows Server instance. This is why you want to be careful to evaluate the risk of untrusted code for each Windows Server instance, and balance the security versus performance tradeoff for your environment.
    Note the push here to update to Windows 10.
    https://cloudblogs.microsoft.com/microsoftsecure/2018/01/09/understanding-the-performance-impact-of-spectre-and-meltdown-mitigations-on-windows-systems/
  • 1 Reply sorted by
  • Intel adds to this
    The performance impact of the mitigation on 8th generation platforms (Kaby Lake, Coffee Lake) with SSDs is small. Across a variety of workloads, including office productivity and media creation as represented in the SYSMark2014SE benchmark, the expected impact is less than 6 percent. In certain cases, some users may see a more noticeable impact. For instance, users who use web applications that involve complex JavaScript operations may see a somewhat higher impact (up to 10 percent based on our initial measurements). Workloads that are graphics-intensive like gaming or compute-intensive like financial analysis see minimal impact.
    Our measurements of the impact on the 7th Gen Kaby Lake-H performance mobile platform are similar to the 8th generation platforms (approximately 7 percent on the SYSMark2014SE benchmark).
    For the 6th generation Skylake-S platform, our measurements show the performance impact is slightly higher, but generally in line with the observations on 8th and 7th generation platforms (approximately 8 percent on the SYSMark2014SE benchmark). We have also measured performance on the same platform with Windows 7, a common configuration in the installed base, especially in office environments. The observed impact is small (approximately 6 percent on the SYSMark2014SE benchmark). Observed impact is even lower on systems with HDDs.
    As we collect more information across the broad range of usages and Intel platforms, we will make it available. Within the next week, we intend to offer a representative set of data for mobile and desktop platforms that were launched within the past five years. For those Intel customers who are worried about performance impacts, you should know that we will work on creative solutions with our industry partners to reduce those performance impacts wherever possible.
    https://newsroom.intel.com/editorials/intel-security-issue-update-initial-performance-data-results-client-systems/
