Nebula 4100 Slant Gimbal
    • High-Torque motors with built-in encoders
    • 1.8kg Camera Payload
    • 700g only weight
    • 8-10 hours battery life
    • Support direct charge
    • Ergonomic handle
    • Hidden cable design
    • 360° unlimited rotation for all 3 axes
    • Joystick, one key recording, one key back to the midpoint
    Available at out deals for special flash sale offer: $499
    I want to buy this gimbal.
  • 3 Replies sorted by
    Nebula 4100 Slant keeps most of the great features from the Nebula 5100 Slant, the 360° unlimited rotation, the 8-10 hours’ long battery life, manual focus adjustment and the useful functions: one key midpoint returning, time-lapse, roll follow mode, auto face tracking...
    Be worth mentioning, the Nebula 4100 Slant is the most flexible one among the 3-axis Nebula gimbals, all because of its exclusive accessory, the 5-axis connection plate. This little optional item can be mounted onto the Nebula 4100 Slant as a joint part to connect a 5-axis spring arm/phone holder/Nebula Gyro Jib as needed. The Nebula 5-axis spring arm is a practical accessory for absorbing vibrations caused by user’s steps. With the 5-axis connection plate, you can set the 5-axis spring arm onto the Yaw axis of the Nebula 4100 Slant, the eye-level is suitable for shooting.
    800 x 373 - 48K
    800 x 364 - 43K
    800 x 371 - 38K
    800 x 680 - 89K
  • Another video:
  • Flash deal! Check first post in topic.
