Lectrosonics PDR Portable Audio Recorder
  • 10 Replies sorted by
  • PDR Firmware Update v2.00 - 20 April 2018
    • Added support for industry standard iXML header data.
    • Enhanced user interface with submenus and new functions such as jam from real time clock, scene and take numbers, longer file segment sizes, improved file naming, recognition of SMWB recordings, improved progress monitoring bargraph.
    • Improved robustness in the event that data is inadvertently written to a card during the recording retrieval process.
    • This is a major release with many new features.Please consult the release notes included in the firmware download .zip file for details.
    https://www.lectrosonics.com/Support/category/93-firmware.html
  • On a shoot that scale they can afford wireless instead.
    It just seems like an extraordinarily small niche that the PDR is targeting, but heh.... at least they're serving them, which is good.
  • Let's assume hypothetically a DR10L only lasts half as long. Ok then, I'll buy two! Still cheaper.
    Let' assume realistically that your savings resulted in cancelled one day of shooting of just small size TV series.
    Different perspective, isn't it? Not looks like savings anymore.
  • Have no idea how it is related to oscillator.
    Never said it is.
    Actually Tascam DR-10L is really not made up to beating and harsh conditions.
  • Weird, I wonder why they even have a 32bit option
    Surprising indeed that it lacks good TC, kills part of the reason to spend the extra dosh on a PDR vs just getting the cheap Tascam DR10L
    As for TXCO, it has real meaning if you have same stabilized oscillators in cameras and other audio equipment you use.
    Last PluralEyes versions can correct drift and output corrected audio.
  • One thing interesting is that it does not have TXCO (temperature compensated oscillator). That is very bad for such price device.
  • Review
    You can choose headphones or line out, with recording bit depths of 24-bit and 32-bit. I did all my recordings in 24-bit, which are the same circuits as the SM and LT units. The audio is really clean with the 30 db of limiting. According to Lectrosonics (32-bit is actually 24-bit padded with zeros, so more space is taken up on the card).
    http://www.dvinfo.net/article/production/audio/review-lectrosonics-pdr.html
    700 x 455 - 45K
