Driftwood Cluster X series 3:│moon T7│ЅріzZ T6│Nebula T7│Drewnet T9│
  • 1811 Replies sorted by
  • @sk810, thanks for getting back to me! That makes sense. I was playing around quite some time with different hacks and different versions of Moon until I found one that worked well and reliably for me. However, I forgot to make a note. Lesson learned :)
  • Moon T7 with Sigma 18-35 F1.8
  • Nicely done!
  • More Moon T7 footage! Still using this thing despite having a GH5.
  • Greetings from Vietnam. Patched with the latest T9. Very happy with its quality upgrading from Cake, although it gave write errors sometimes.
    Panasonic 25mm f1.4, no colour grading.
  • Hi guys, I'm a newcomer, have GH2 and just installed MoonT7. I wanted to ask where can I check all the details concerning video bitrate. Premiere pro gives me some crazy numbers with many zeros. I just want to be sure that I really installed the hack.It seems that I did - 20 seconds videofile weight 300 Mb, seems to be alot? But sometimes after turning on camera propose me to install an update, so I have doubts that first installation was successful. Thanx for any advice!
  • After installing the patch format the card in camera.
    To check the bitrate and other data download Stream Parser from here.
  • bokeh test with Kamlan f1.1 50mm, 1080p24 and 720p60 for slowmo shots. Drewnet T9.
  • - 函館市 Hakodate-shi, Hokkaido, Japan -
    Shot on ' Lumix GH2 + Leica DG Nocticron 42.5mm f/1.2 ASPH. POWER OIS Lens ' [with Driftwood Moon T8 24L]
    recorded a short video from my last trip to Japan. Nocticron is also my favorite lens in Lumix. The picture profile setting was set to cinema all-2
    ※ The moon t8 boasts good quality enough even if it is set to 24L.
    -> Confused with the moon t8 post. I would appreciate if you could delete the comment.
  • Still in love with my Moon T7 on my GH2. This experimental one even got an award :) Lenses: Konica hexanon 40mm, Fujian 35mm. Cheers
  • And here's another one, messing around with the tint in camera :)
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
