I haven’t been able to do any scientific testing. However, I must say that the higher FPS with MJPEG looks promising. It definitely changes the frame rate.
The issue might be that it is upping the frame rate of the video to 120 FPS. However, it could also be shooting 60 FPS and speeding the footage up to coincide with the 120 FPS file.
I am going to do some low light, I.Contrast, with greater than ISO 3200, 1080p MJPEG @ 120 FPS shooting tonight. That should cover most of the new changes and a few future hopefuls.
Thanks VK and team. This is the update I have been waiting for since I do a lot of slow motion.
>MPEG is 1920 x 1080, ya? nop, 720p by default. It's still unclear if modifying MJPEG resolution with the hack is just upscaling or really raise resolution
72 FPS works. It indicates it is 72 FPS and it looks like 72 FPS. Not sure if 72 FPS is a good thing or not though? It looks weird and 1/160 of a second shutter speed looks bad with the lights I have near me. Trying 120 FPS now.
I wouldn't call the second bad. I would just say it doesn't have noise reduction. I don't believe that turning noise reduction down to -2 actually turns off noise reduction in all cases even for RAW files.
Your pictures make it look like a difference in noise reduction between the two. I wonder if the new firmware update corrects this issue. Doesn't the new firmware offer improved noise reduction?
I would like to test 3.63d as well please. The ISO Limit patch sounds very interesting. I have done some extensive testing on the I.Dynamic mode and I think I finally have it fiugred out. I will try to post a video demonstration of how it works tonight.
