Imaging Resource ISO test: http://www.imaging-resource.com/PRODS/canon-6d-mark-ii/canon-6d-mark-iiA7.HTM
More videos about features
Canon sensor is still not so good as Sony made sensors
https://www.dpreview.com/articles/3416153698/canon-eos-6d-mark-ii-dynamic-range
In stock
https://www.dpreview.com/reviews/canon-eos-6d-mark-ii-review
Conclusion As it should be, the EOS 6D II is a better camera than its predecessor in almost every way. With plenty of resolution, respectable burst shooting speeds and pleasing Canon color, it's a camera that's capable of producing great images in a variety of situations. Despite this, it is simply overshadowed by competition that is made up of more capable cameras at similar or lower prices.
[VK: added samples]
Review
The 6D II records video in .MP4 or .MOV format using the MPEG-4 AVC / H.264 codec, with audio being recorded in Linear PCM (.MOV) or AAC (.MP4) via dual front microphones (producing stereo sound) or the 3.5mm stereo input jack. Sound recording levels can be set to Auto, Manual (64 levels) or Disabled entirely. Unfortunately, Canon decided not to include a headphone terminal in its budget full frame offering. Wind Filter and Attenuator options can be set in the sound recording menu.
One particularly annoying quirk regarding movie recording with the 6D II is that when the camera is set to Shutter Priority (Tv) or Aperture Priority (Av) mode, the camera will vary both the shutter and aperture to maintain exposure, the same as if the camera were set to Program (P) mode. For the ultimate control, use Manual (M) mode with Auto ISO (as needed).
http://www.the-digital-picture.com/Reviews/Canon-EOS-6D-Mark-II.aspx
Review
The camera records FullHD video at frame rates up to 60fps, with stereo microphones built-in. The ISO speed available goes up to ISO25600 in Auto mode. Manual ISO settings can be expanded to H1: ISO51200, and H2: ISO102400. A full range of frame rates are available, including 59.94, 50, 29.97, 25, and 23.976fps. Videos are recorded as MP4 (MPEG-4 AVC, H264) files, with options of IPB Standard or Light, this results in a bitrate of 58-59mbps.
You can adjust the audio levels manually, or leave them on auto. There are wind filter and attenuator options. HDR movie recording is possible as one of the scene modes. In-camera 5-axis Digital IS available (options are: Off, Enable, and Enhanced). As the electronic image stabilization reduces video quality, we'd recommend the use of a lens with optical image stabilization, or the use of a tripod (or monopod).
https://www.ephotozine.com/article/canon-eos-6d-mark-ii-expert-review-31095/
All options are in stock now:
New firmware is coming within month. Some video improvements must be included.
Video user guide
Review
Positive points of the Canon EOS 6D Mark II include improved AF system, the fantastic articulating touch-screen and a new LSI which facilitates a better high noise performance. Sadly downsides are present too. Having a single SD card slot is disappointing at this price point, while 4K video is starting to become so standard that to see it left out of a £2,000 camera is definitely a let-down
http://www.photographyblog.com/reviews/canon_eos_6d_mark_ii_review/
DXO Sensor performance
With dynamic range it is weird
But on separate measurement it is
https://www.dxomark.com/canon-eos-6d-mark-ii-sensor-review-great-color-iso-performance/
Review
EOS 6D II camera supports two video recording formats: MP4 and MOV, although the latter is only used for time-lapse recordings. For MP4 recordings, the MPEG4 AVC with H264 inter-frame compression applies.
Video resolution is still limited to 1920 x 1080 pixels and the maximum frame rate is 60p/50p (NTSC/PAL). When shooting movies, users can take advantage of the Dual Pixel CMOS AF, which supports phase-detection autofocus across a wide area of the frame for faster and more accurate focusing to yield smoother movie recording.
Enabling Digital IS adds 5-axis image stabilization but crops the frame to minimize camera shake. It's useful for handheld shooting while walking and when shooting from a moving vehicle. This function can interact with the optical IS function in Canon lenses to provide a higher level of stabilization.
http://photoreview.com.au/reviews/dslr-cameras/advanced/canon-eos-6d-mark-ii
Canon EOS 6D Mark II DSLR Camera, $1715
