Yi 360 VR camera, 5.7K video at 30fps
    • Two fisheye lenses 220 degrees each
    • Two 1/2.3-inch 12-mp Sony IMX377 sensors
    • Ambarella H2V95 processor
    • Unmatched video at 5760 x 2880 @ 30fps or 2560 x 1280 @ 60fps
    • Photo 5760 x 2880
    • In-camera stitching at 4096 x 2048 @ 30fps video and 5760 x 2880 photo.
    • Wireless streaming at 2560 x 1280 @ 30fps, 6-13 mbps bitrate to YouTube, Facebook, Weibo or other
    • Shutter speed up to 30 seconds
    • Time lapse mode
    • 75 minutes battery life while recording at 4K.
    • Uses Micro SD cards
    • Removable battery
    • Micro HDMI port
    • USB C port
    • 102x53.2x29.6mm
    • 170 grams
    • $399
    • available in June
    More info and preorder https://yitechnology.com/yi-360-vr-camera
  • 31 Replies sorted by
  • 360 5.7K Video:
    1080 HyperFrame Video from the above:
  • Found: Free software that will merge the stitched 5.7K clips from the Yi 360 VR and produce a 5.7K 360 video at a high bitrate - the Virb Edit software! You can also add transitions. Here is an example:
    Select 5K (2880).
  • Good use of Yi 360 VR in a night club:
    This is a 5.7K 360 video.
  • In sunshine:
  • @Paulo Thanks. I had tried exactly that. It does not work (Smart Renderer will not merge the stitched video clips), and the reason is the Yi video clips are 5.7K, not 4K like from the Gear 360 (which I have used in exactly the way you describe). Smart Renderer cannot handle 5.7K videos. No software appears to be ready to edit 5.7K video at 2:1 aspect ratio, except for VIRB software (because the VIRB 360 is 5.7K), but that software is just completely flawed and produces awful low-bitrate videos (see the VIRB forums; this is not its only problem).
  • I don't have the Yi 360 camera and I'm not sure if this will work for that camera but in my case with the Gear 360 camera, I use the phone app to stitch the footage and then edit the stiched footage in Smart Renderer 5.
    Try stitching the footage first using Yi's 360 software and then try editing it in Smart Renderer 5 (The software was recently updated). Once you export the edited video, inject 360 meta data into it using the software that is mentioned here.
    https://support.google.com/youtube/answer/6178631?hl=en
  • In a NYC subway:
    Still have not found software that can merge and render 5.7K 2:1 video at high bitrates. Not Vegas Pro 15, not Cyberlink Ultra 16, not VIRB software, not GoPro software, not Kodak 360 software.
  • My initial review of an actual production model.
    The latest consumer-grade 360 video resolution frontier is 5.7K. And the Yi 360 VR gives you that for $399. Note: the GoPro Fusion only gives you 5.2K (at $699); the Garmin Virb does 5.7K also, at $799!
    The camera is easy to use with the (Android) app: connected instantly, no password asked for. All the settings were there. Live view with little lag. The max bitrate for 5.7K/30P is 120 Mbps. I chose that.
    You can set everything on the camera without the app - there are buttons and a bright OLED screen with the settings and options.
    I used the included tripod attached to the Yi "selfie" stick, making for an extendable, portable, sturdy and near invisible stand.
    Shot for about one minute on a dim day at dusk - so little light. The camera has f2.0 lenses. The resulting video is also dull, but not noisy. Well exposed (there are ev controls, but I was on full auto).
    I stitched the file in the free Yi 360 desktop software, using the best 'optical flow' setting. Stitching takes a long time, but it is really good. The one minute video took 22 minutes to stitch. The produced 360 stitched video at the highest quality setting is 5.7K at - 317 Mbps! The high bitrate (it's optional) is so that you can place the stitched video into another editor for color correction, clipping and merging, with little resolution loss.
    I used the resulting video as-is to upload to YouTube, after injecting the metadata according to YouTube instructions - easy, instantaneous and no degradation of the file.
    The uploaded raw video is here:
    YouTube recognized it as a 360 video, and can play it in 5K, the highest resolution. You want to see it in 5K, no matter what your viewing screen, since, again, you are only really seeing a part of the scene at a time.
    In terms of quality, I cannot see where the stitch is; best I have ever seen. No distortion, no CA, a good picture. Better than the 4K 360 videos of the previous generation for sure, but of course not 5.7K or even 4K as viewed in a 360 slice.
    I also uploaded the video to Vimeo, which now plays 360 videos, so you can download the original raw (stitched file).
    I can barely play the 5.7K, 317 Mbps file on my computer. But it was ingested easily into Vegas Pro 15 and I could easily color grade it and produce a new 5.7K version.
    Next is to see how the video looks from a scene lit with sunshine.
  • And the price has remained at the original announced price of $399. Seems not to be available anywhere else yet.
  • YI Technology (YI), the leading provider of advanced, intelligent imaging technologies, announced availability today of its unique YI 360 VR camera (“YI 360”) at Microsoft Store locations in the U.S. and Microsoft.com. The YI 360 makes high-end virtual reality video easy and accessible to anyone who wants to create and share content.
    With a simple, handheld and mountable camera design, the YI 360 VR is the first VR camera to combine high-fidelity, 360-degree video capture, an easy mobile application along with 4K instant, in-device stitching and 4K live-streaming to any sharing channel. With these innovations, the YI 360 VR™ provides a complete solution for creating immersive, 360-degree video experiences easily, quickly and anywhere.
    “At YI Technology, we challenge ourselves to bring the most innovative technologies together in a way that is simple, enjoyable and useful for anyone, from kids to professionals. VR is no exception,” said Sean Da, CEO of YI Technology. “Today’s solutions for 360 capture and sharing force users to choose between an affordable low quality, low resolution product and an overly expensive, highly complicated product. That is why we worked so hard to perfect YI 360 VR. By combining the best components, rigorous industrial design and many years of testing, we eliminated the cables, confusing interfaces and bulky components and added 5.7K fidelity, 4K in-device stitching and 4K live-streaming, all in a handy, affordable package.”
    Already known for its YI 4K+ Action Camera, the YI M1 Mirrorless Digital Camera and the YI HALO professional 3D camera, YI’s launch of the YI 360 VR Camera offers users a consumer-grade, affordable yet professional quality option for capturing and sharing 360 degree footage.
    Vivid, Easy, Live - Key YI 360 VR Features:
    • Two 220-degree 8 aspheric glass lenses with f/2.0 aperture
    • In-camera video stitching for up to 4K/30fps
    • PC application for 5.7K/30fps video stitching
    • Built-in 2.4GHz and 5GHz Wi-Fi for live-streaming in 4K
    • Five video preview options within the app including stretched view, little planet, round, panoramic and dual VR view
    • Up to 60 minutes battery life recording at 4K/30fps
    • Compatible with Oculus Rift and HTC Vive VR headsets
    • Pricing & Availability
    At $399, YI 360 VR™ is now available for purchase at Microsoft Store locations in the U.S. and Microsoft.com. Go to https://www.microsoft.com/en-us/store/d/YI-360-VR-Camera/8ZG9K9SM5BSZ now to purchase or to find a store near you to see a live demonstration YI 360’s vivid capture and live sharing for yourself.
  • It's still the pre-order price, so nothing has changed. The question of what the price will be when the item is actually in stock still remains, though I bet you are correct and it does not go up then.
  • So, finally it was bullshit marketing stunt with $100 increase, price same as announced first
    https://www.bhphotovideo.com/c/product/1337213-REG/yi_technology_360_vr_camera.html
  • The Yi 360 VR release date has been delayed again.
    Still some hope for November release.
  • Review. He also compares it to other cameras. It'll definitely be interesting seeing a comparison between the Yi 360 and GoPro Fusion in the future.
  • Generally pre-orders are for suckers. But in this case there is a payoff (perhaps).
    Why not pre-order? Availability is in December, and you can always cancel. No one gets your money until shipment. This locks in the price, and I am sure there will be videos available before the item could be delivered to inform on whether to bail. Already the guy from 360rumors.com has shot video, and what can be seen easily beats the 4K 360 shooters we have now.
    Also, Yi's 4K action cams have proved to be more than good - class-leading - and to fulfill all the promises made (albeit sometimes with later firmware upgrades). Yi is no longer some obscure little manufacturer.
    Of course, the future $499 price announcement may prove to be untrue, but that is only relevant if you want the camera. And the fact that the famous competitor (with no better specs) from GoPro will be much more expensive probably emboldened Yi to raise their price.
  • Yi idea is now increase price to $499 or jus tease people with it
    $399 preorder price is still same - https://www.bhphotovideo.com/c/product/1337213-REG/yi_technology_360_vr_camera.html
    If you ask me - avoid this camera at all costs until real performance and lens quality and firmware buys will be know.
  • Will be coming in September
    327 x 68 - 7K
