Some news for all, @czoka and me just found that these settings doesn't work properly with low speed SDHC cards, the problem is skipping frames. Transcend 16GB Class 10 doesn't work, and all cheap SDHC cards seems like too. 100% works with SanDisk SDHC UHS Class 1 95MB/s 8GB.
I have tried the custom firmware outside ( great sunny day ) with sandisk extreme SDHC card, works great, great quality .
Keep up the good work @humpman !
@humpman I was getting used to hack GH1 as following: 1- run ptool,exe 2- load firmware gh1_132.bin 3- click on set a ( or b,c,d...) 4- Save firmware to gh1_133.bin
How are we using with user and set a? Should I rename user.ini to b or c... then load both together?
to use the @humpman setting, put user.ini in the same directory as the ptool.exe
@ yskunto: Do I need to rename that user.ini to b, c ...j then click on that to show user setting then click on set a to save to new firmware? I was confused?
user.ini has nothing to do with settings, it adds new patches to selection available.
@tinbeo just watch this video, tutorial in the end
Thanks all for helps. http://www.personal-view.com/talks/discussion/comment/224468#Comment_224468 Not only me confused of user.in. -;) I am on Mac, run P tool with Wine. When I load the firmware with humpman's video instruction, nothing is shown up in user setting. Will have to click on seta to shown user patch
                  Thanks @humpman. I used your Jan 24 user.ini and seta.ini. In addition I enabled "Wrapper->Native 24p/25p" because I want 24p but still when I inspect my MTS file using StreamParser I do not see any value for "Stream: Mode" in the "Information" box. I was expecting to see "1080/24pH (GH13 Native Hack)". How do I shoot in native 24p? Thanks!
@kanth those settings only for interlace, there is new setting to turn 2997i into 2400i(4800), and also interlace in GH1 it's just programm interlace so you can easely turn it to native in video edit programm. Native mode in GH1 is unstable.
Ok - thanks @humpman
@humpman so for example if I were to just load up the 75mbps patch in ptools, turn on 2997i to 2400i option, it's pretty much progressive 24p once transcoded and should for all intents and purposes be treated like 24p (in regards to setting shutter etc)?
My main concern with the interlaced mode is losing frames when transcoding the MTS since Davinci Resolve doesn't support the MTS or the AC3 audio embedded within the container so I have to transcode it anyways and I don't want to lose data if it's not automatically reverse telecining it (in the case of the 75mbps patch being 3:2 pulldown from the 24p sensor output).
When I tried your patch, the mediainfo didn't show anything different for the interlaced mode other than the frame rate being 24fps.
@humpman ok, that's where I was confused, in MediaInfo and other applications, it shows the framerate as 24fps, but also shows that it's interlaced/separated fields, in none of the applications does it say 48i so I was confused as to how there seemed to be a single frame for each frame rate as opposed to a visual mix on pause/pans.
So I'm still getting each 24 frames progressively in a 24fps timeline, it just doesn't have to do a pull-down from 48i. That's where my confusion was. (I understand progressive well enough, interlaced is where my brain got fried)
The other night I was trying to get your improvements on top of the 75mbps patch, but I wanted to keep the motion jpeg configuration from LPowell's patch instead of doing a 2fps timelapse mode. Course I guess your user configuration doesn't play nice with Powell's original settings for SH (60p) mode since the camera froze up on some panning tests.
But for tonight's event I'm using the Lpowell 75mbps configuration with a minor change of using the "2997i to 2400i" option that I discovered from your work thus far (I haven't seen this mentioned anywhere else so far, and it seems to make so much more sense than risking instability attempting a native 24p wrapper)
Ultimately what I want to get (I'm only working in NTSC):
From your work:
From Lpowell's 75bmps
Also since I'm using an external recorder for audio most of the time, do you think I would gain any stability by reducing the AC3 bitrate/buffer? I mainly want in-camera audio just to slate it.
@humpman using your user.ini and configuration examples I kind of 'mashed' this together using LPowell's 100mbps Max Lat patch as a base. ( https://pastebin.com/dpzYfp33 )
Changes on top of the Max Lat patch in pTools:
Two Video examples against bunch of texture at ISO 100, 1/50th, and f/5.6 on AVCHD and MotionJpeg
And trying out ISO 1600/3200 with just the user.ini settings alone seems to be very very clean compared to just stock MatLat or 75mbps patch. (would post, but the example I shot is a messy living room lol, will get something tomorrow).
Tomorrow though I'm going to try to do some recording outside (maybe some heavy foliage if it's bright and sunny) though any suggestion of real world scenes to test it would be appreciated. But just learning about the 48i option from you has been quite nice for my workflow
Will do (though I don't shoot PAL, would using 24p/48i achieve the same purpose?)
PS: just did this ~10 min video (ISO 400, f/3.2, 1/50th, with "Smooth" film mode -2 sharpness, -2 contrast, -2 noise reduction, and graded in Davinci Resolve 12.5)
When I get to the campus later today, I'll do a controlled series of clips in the studio dimming the lights and what not.
(I also have an Breakthrough X4 10-stop ND filter to force it outside...)
Not sure if this is useful to you or not in the mean time.
In the studio with the lights off (most of the windows are blocked off) I shot the following at ISO 3200, 1/50th, f/2.0 in FHD did some pans, stopped on some darkened scenes, panned back, etc. Using the "Smooth" film mode, -2 sharp, -2 contrast, -2 noise reduction and I uploaded the MTS file directly to youtube.
the same at ISO 100 with the LED panels turned on and dimmed to 10% to allow for it to give me near the same meter reading at ISO 100 with all other settings the same.
edit
Looking back at humpman's example I re-did a static shot with the table layered with some texture/pattern.
I set the light panels so that I got roughly a half a stop to a stop under exposed on the meter and set the camera to ISO 3200, f/3.2, 1/50th, FHD, Smooth (-2 sharp, -2 contrast, -2 noise reduction) and uploaded the MTS file directly to youtube.
@zcream seems I made a rather stupid error in not matching up the FHD/SH bitrate (only the overall changed), so when I bumped them higher than what humpman had, and did a test shot at 3200 in low light, I immediately saw what you were talking about in playing it back for AVCHD the funky mud effect going on. I realized my error when the average bitrate kept staying around 50mbps. (though I did least get some good footage downtown today with only a crash at the end of the night in low light when I was walking one handed with the camera all bouncy in motionjpeg).
So... yea...
Hi All. I am Alessandro from Italy. Because I have read all abaut this amazing discussion I would like to sharing my little project. I used GH1 + Canon 50mm ssc FD + last settings by Humpman (thousand thanx). I think that this little camera is amazing, except for its problem abaout NFP noise fixed pattern :( Watch it in 1080, please.
Here i upload some frames take by original master in cineform, to watch quality.
https://drive.google.com/open?id=0ByUlFpQa8E56S2VWUmhXRW8xejg
Thx and sorry for my English, I'm Italian do You know...
Hey @humpman and all who worked on and helped with this hack, just wanted to express my gratitude to you! I just picked up a gh1 again, (for 110 € plus the 14-42 mega ois, man what a bargain) on ebay as an addition to my 2 GH2s.
I got super excited over the last months finding and reading the thread and seeing that you got rif of the muddy compression in dark areas which finally got me to search for one again.
This is definitely the goto patch for the GH1 now, thanks so much! It will be my cam for experiments, light run-and-gun in good lighting conditions, experimentin with black and white and high contrast lighting, throwing it in the bag without holding back, b-roll and so on. Great little toy/tool to have, since i love it's picture characteristics.
@AlexGH1 great video though it's offline now, what happened?
All in all thanks to all of you and i hope you had a "geruhsame Weihnacht" as we say here in germany.
Best, MrZz
