Sony IMX294CJK - 4K 120fps m43 HDR sensor
  • Exceptional low-illumination performance
    Exceptional low-illumination performance of SNR1s: 0.14 lx is realized by use of a large-size optical system and by expanding the area per pixel to 4.63 µm. This makes the IMX294CJK ideal for security camera market applications that require low-illumination performance.
    High-speed movie imaging
    This product realizes high-speed movie imaging with a 4K angle of view at the high frame rate of 120 frame/s, and also enables high-speed imaging at 60 frame/s in HDR drive mode.
    In addition, use of our proprietary high-speed serial interface SLVS-EC together with high-speed imaging enables image transfer with few signal lines. This product is also equipped with a general-purpose MIPI (CSI-2) interface, and supports connection with a general-purpose ISP (Image Signal Processor).
    Quad Bayer Coding HDR
    The IMX294CJK uses a Quad Bayer structure, and outputs data binned in 2 × 2 pixel units in normal mode. In HDR mode, integration can be divided into long-time integration and short-time integration for each 2 pixels in the Quad array (Figure 1). In this case there is no time difference between long-time integration and short-time integration, which realizes HDR with little blending offset when imaging moving subjects.
  • 3 Replies sorted by
  • It would be great to see this in a GH6s-type camera- lower MP, better sensitivity. Or will Panasonic be making their own sensors again by then?
    Maybe Blackmagic? Would Sony sell to them? I'd love to see a new m43 cam from Blackmagic that does 4K60 and records to simple SSDs. An update to their first cam, just not in the lunchbox form factor.
  • This is a revolutionary sensor. I hope the image quality can be good for video/cinema, not that bad videoish image from automotive/security sensors.
    The GH5 is a complete camera with all features needed, the only thing missing is a HDR sensor like this.
    HDR has been a feature for automotive/security sensors since some time ago. Why photo/video cameras are not equiped with these kind of sensor is a maketing mystery.
    Probably Sony will keep this sensor only for security/automotive cameras.
