GH5 Panasonic camera, from anticipation to love or hate
  • 2083 Replies sorted by
  • @philiplipetz
    finally some good hands on camera
    good imagery
  • Besde the flicker in that video, what's going on with all the pixelisation and macrobloking, codec is completely broken. Looks like the poor grading where they pushed it to hard, but still it shows definite lacking of bitrate for enciding so much detail at that high framerate.
  • @caveport - on the GH4 you can enable Syncro scan when using VFR so would assume you could just as well on the GH5 (another example of why Panasonic needs to get the GH5 in the hands of people who know what they're doing to avoid terrible footage like this!)- My C2 setting on my GH4 has synchro-scan enabled w/ shutter at 1/119.99 sec (closest I can get to 1/120) and 1080 96fps conforming to 23.98p 1080 since I am based in US and our flicker is on a 60Hz cycle - which is kind of beauty with 180 FPS in North America, you should be able to use a 1/180 shutter if needed for most light possible when shooting at 180fps and as a factor of 60, should cancel out most if not all flicker. Rest of world could do same with 150fps (1/150 sec shutter) with 50Hz electricity - or just bump shutter to 1/200.
  • so sarcastic of you
  • cos for my understanding we dont need so much back prossesing at 480fps. so why so much noise then, i dont undestand why so many improvements but no DR from that sensor, well capaciti can be improved by lowering resolution.
    Minimum resolution they could have is 4K, but as 90% of buyers still shoot videos only from time to time it means big reduction in sales. Proper scaling actually is within few percent of lower native resolution.
    We have FAQ item on this - http://www.personal-view.com/faqs/camera-usage/general-camera-usage-faq#more-megapixels-is-worse-isn-t
    It was mentioned before. less resolution, bigger well capacity. another vwersion shoul be grate.
    end
  • @endotoxic
    My rant is about to much years for so little improvement in DR, come on!
    Well, if you understand how sensors work, why you ask so much from sensor of same size?
    The only was to rise DR in normal brightly lit situation is to lower noise as your well capacity is more or less fixed.
    And in GH5 we have so much asked sensor stabilization, and it means thermal noise rise.
    As we'll get GH5 we make sure to make thermal videos of sensor after long shooting session and compare it to GH4 and GH3.
  • @caveport
    English its not my native lenguage. So maybe that is why you may not be able to understand.
    Im a professional director and cinematographer, i have myown company, ive used all models of cameras arround, worked with them and test them on field ( exept FS5 and new 8k monsters) I know what im talking about.
    https://www.youtube.com/channel/UC0zfUSEmtExNRznNN3mYY1g
    https://vimeo.com/siriusfilmsperu
    I also know about sensor tech and general( prosessors SOCs FPGA prosses of lythography and realated stuff) not into a scientific or mathematical level, so i know i have a deep understanding of what is going on. Even though vitaly constansltly make me look like a real ignorant. I accept it cos he knows what he is talking about, but is sturdy as fuck, as me.
    I i recomend this camera is cos i know what kind of tech is behind this, seeing that motherboard, the part of the non soc where all voltage controlers and staked chips are, is more interesting to analize, high level tech there on that camera.
    @1917
    i have the same poit of view of you, thank you for undestanding.
  • @caveport Alexa now is a reference camera, so anyway all other cameras will compare with it. Already 4 years since we have cameras that twice cheaper than Gh5, and close to Alexa in terms of dr, color, organic motion feeling, it has size of smartphone and shoot RAW!!! - i mean bmpcc (and bmmcc). BM footage easily mixing with Alexa footage in many projects. Yes, Alexa is 1000 times better for real production, but bmpcc footage is much closer to Alexa than GH cams footage. So technicaly good DR, color and compression is not fantastic for gh5 price segment today (and yesterday) and may be it is only marketing reason to so slow evolution of this parameters in dslr or mirrorless photocameras. About gh line - it is very important to have progress in DR, it is more important than 4k60p (or 6k)))), a lot of commercial projects today still shooting on Alexa in 2k, because there are no any reason to shoot it in 4k (4k is great feature anyway). I think in 2017-2018 we will see small and cheap camera with 15 steps of dr and raw.
  • @Manu4Vendetta LED lighting flicker. Synchro scan can be used to minimise the flicker but I'm not sure if the GH5 can enable it in variable frame rate mode.
  • @endotoxic I really wish I understood your posts.
    Most of what you say, such as "Bad highlight handling. Extreme contrast allways. Blacks with no data. Moire on some scenes." is just silly. You really can't evaluate a camera by looking at a few online videos. Then you follow up by saying "I you want a pro suggestion sell your g85 and buy the GH5. PERIOD. All is better."
    So what do you really think? GH5 is good? Or not?
    Comparing to an Alexa is not useful as the GH5 is not in the same category at all. Yes I know the Alexa is considered to be the benchmark for professional digital imaging ( I grade Alexa footage daily) but it's a different form factor and technology. No other camera maker comes close, which is why they are used for major cinema productions. No other compact or DSLR camera brand will compare well to Alexa either so your comparisons are pointless.
  • I can't understand why Panny don't hand their cameras to decent videographers. Except for Neumann's short video I haven't seen anything semi-good from GH5 yet. I remember the same situation with GH4, lots of horrible crap in the beginning with some nice stuff showing months after release.
  • I see something strange in this slow motion, can be the type of artificial light.
  • @Scot
    With all due respect. The cost of this thing is nothing for what you get. I you want a pro suggestion sell your g85 and buy the GH5. PERIOD. All is better.
    Its my rant, that being here in forum since GH1,( i remember...hmm time has passed) almost same dynamic range as first sensor. I see all the positives, if you could see what can be done on a properly hacked GH2, you could be very surprised.
    But all this time has passed, and from 10 to 12 stops in almost 8 years...COME ON PANA, its not all back processing, its also wavelengths and sensitivity to those.
    Why Alexa is so good? is the sensor, the processing is also very good, but that sensor even up-scaled gives you 4k detail !!!
    I cant compare Alexa to GH5 but all this tech for same DR. i know Panasonic dont want to cannibalize Varicam set, but come on, give us one more stop, even perceptual.
  • I think you should wait and see till the camera actually ships. Even if it were the exact same sensor it now is non cropped in 4K and has internal stabilization. Two great things to me the test will be if it does anything twice as good as my current G85 to justify the hefty price tag.
  • USER RELATET FAULTS
    come on @Eno. Throw that to an alexa and lets see how it handles user faults.
    I really dont see improvements over gh4 image wise, exepect noise reduction and 10bit flavor for the masses.
    keep the frame rates and bitrates for other time
  • then i said: @Eno @Vitaliy_Kiselev
    It seems they threw on all to the venus engine and only overclocked the sensor.
    Ohh, now everyone likes the sensor?
    Well i dont see any improvement just low light. For general purpose its ok, but selling 10 bit HDR ready with that dynamic range, seems stupid.
    I thought this baby was capable of 13.5 stops, but seeing this, only low light is improved. Yes in that aspect for sensor size, is good noise reduction algorithm, cos with that back prossesing at 480fps makes good noise. Unless is REALLY ALL NEW SENSOR.
  • @endotoxic, what sensor issues? Everything you mentioned are user related faults!
  • That sensor has several issues.
    What kind of issues?
    All you listed is not sensor related (for specified sensor size, of course). It is in camera processing.
    Now what.???
    Lets hope for the ones cooking in factory to be revised versions from pre production models. Bad highlight handling. Extreme contrast allways. Blacks with no data. Moire on some scenes.
    Now im begining to think if 10 bits was worth it. It seems the threw on all to the venus engine and only overclocked the sensor.
    It seems to me that the dynamic range is off. Maybe lower than gh4 in this pre production version.
  • @JamesAllenVisual
    I think no one told that it is free. It was good idea, but nope.
  • I was doing some digging and B&H Photo in the US confirmed it was not a pre-order freebie - inferring it was just Internet rumour. I didn't find anything else talking about it other than a few comment threads so I think it's safe to assume it won't be free at all. Though the Australia thing is interesting so may very well be a thing there like Fitzy says.
