It is not so simple as it can look, as you need sensor with proper spectral response as well as proper integration hemisphere.
Proper human sensitivity match (aka v-lambda curve) is a must. Most else you can compensate.
Good cheap lux meter that is more or less accurate (it is considered around +-10%) is, strangely, not so easy to get.
From really cheap ones, I suggest to get this one - https://www.aliexpress.com/af/lux-meter-lx1010b.html (with large white integration cover).
It is far from perfect, but not very bad for many lights.
Even this function can have versions (newer one are more precise)
https://www.ecse.rpi.edu/~schubert/Light-Emitting-Diodes-dot-org/Sample-Chapter.pdf
Not so cheap one
Make sure to check http://www.slideshare.net/theilp/pls-2014-is-measuring-led-illuminance-with-a-lux-meter-accurate
