What about when you transfer the card onto a computer? For example, it always exports as the name "P8662747" or something like that where I want the time code to show as the name. Is this possible?
CheesyCam has posted a procedure to set GH4 clocks from Image App. Select "time of day" for time code. They will stay in sync for a few hours.
http://cheesycam.com/timecode-sync-multiple-panasonic-gh4-cameras-multi-cam-editing-fcpx/
Unfortunately, this method does not work. I've tried it using both the Panasonic Image app and the Lumix app from an iPad 2. Neither method gets real sync. In fact, you can get closer sync just by setting a time manually. Sad, as I was hoping this would work. For now, all that really works is external sync.
