I have a year old mbp. Me no apple fanboy. I hate apple craps, but I'm into iphone app dev so I need os x. mbp doesn't support usb3. Arrrrr!!!!
I'm still in fast learning mode. I produce short clips like 30s, 1min, at most 2 mins. Each time adding new flavors such as new AE trick, new color grading, etc. So I don't need a large disk space for now. In fact... I've been deleting my old projects. I was like, "OMG what a crap!!!! my eyes hurt!!!".
Once I begin getting clients, I will need such NAS.
What are you waiting for? Most good PC notebooks already have USB 3.0. As for PC, all but cheap modern motherboards have few USB 3.0 ports. As far as I remember my dock with regulated fan, LCD, etc costed about $30 (and you can change disk by hand within 2 seconds). Actual copy speed depend only on your HDD.
Last year I looked into this stuff for weeks. I was hoping for some breakthrough this year. Maybe thunderbolt, but no cheap product yet. I guess I need to wait longer. Until then... 1TB internal hdd will do it for me. Just dont die on me... Mr.HDD!!! Oh I have a couple of backup ext drives. Not a real-time backup, but it still works.
After some thinking I belive that you must tweak few things, use 7200rpm disks and large files not on system disk and it must be from NAS to your computer to get 80-90MB/sec.
80-100MB/sec :-) Generally, this is speed of gigabit ethernet (with proper router, I use cheap TP-Link).
Small correction - just tested with copy to Acer main system 2Tb disk, got 40MB/sec, back - about 50-60Mb/s. I use USB 3.0 dock and same cheap 2Tb for actual work and they are very fast (in 80-120MB/sec region with large files). Acer is used for storage and backup. But I remember guys who reported 80-90MB/sec.
Since I'm not into NLE, I'd get internal hdd giving 100MB/s. Samsung revealed 1TB notbook hdd. http://www.dvhardware.net/article50208.html Maybe I should get one this x-mas.
>Not NLE. Editing on trascoded files. e.g. ProRes422 or DNxHD115.
I do not know as I do not use transcoded files. And I use USB 3.0 dock for work, server for storage and backup (it have quite handy utility that backup all things in background and you can restore even unbootable computer via provided CD - same software is present on server also) Acer is, generally, computer, so speed is network limited mostly, about 80-100MB/s on such tasks as transcoded files. Using WD Green 2Tb disks copy speed is only slightly less than local disk.
Best solution if you want good amount of storage for extra cheap is 3.5" HDD external dock with USB 3.0. Besides EasyStore I have 2Tb for quick things in additional to 2Tb internal computer drives.
1TB hdd is so cheap. I plan to replace optical drive with an internal hdd. So my mbp will have 2 hdds. Then have a firewire ext hdd and let OS X Time Machine do incremental backup on selected folders. It will keep my desk clean :) This might work for me since I don't have large data. Also It's portable.
Seems like a good deal. But I don't like RAID or RAID like backup after HDD capacity hit 1TB. Even RAID1 isn't totally safe. I could accidentally delete files. Always good idea to save intermediate work often... automatically. RAID is good for that. But I don't think it's a solution to keep data for long time. If that's the case, I'd rather have a pair of 1TB int hdd and 1TB ext hdd. Then let OS do periodic incremental backups. Gotta burn to DVDs (or Bluray disk... I guess) to store longer. Then... I gotta burn them again before the disks go bad. Gawd... its so hard to keep digital data.
