Mark: Yes. I am shooting mainly 2.5K mode 2560x1520, with full stabilizer and geometry correction, so I stayed on firmware 1.1
DrDave: Haven't tested the 24p, sorry.
I suspect the newer firmware limitations may be due to weak batches of Ambarella chips...
Does it offer lock exposure in video modes?
I found my next purchase :) https://www.back-bone.ca/product/ribcage-yi-4k-mod-kit/ You're essentially paying about $350 for a camera that takes c-mount (and S-mount) lenses, and shoots 4k at 24p (new firmware update adds this)!
GoPro Hero 5 comparison
https://bestactioncamera.net/gopro-hero5-black-vs-xiaomi-yi-4k/
Thanks for the links, Mike. I wonder how well the Protune works at 2.5K and 4K ? That is a primary differentiation IMO. As for the reviewer's comment that the GoPro sound is better, I used the audio from the Yi as my primary feed for mix-down on my last video. 'Perfectly' flat, It sounded great with just a little bass boost and treble peaking, so I am not sure how GoPro could improve on that...
Xiaomi(x) Xiaoyi(o) Firmware v1.2.3 added 2.7k mode instead of 2.5k
So. It supports 2.7k/60p, 2.7k/30p with EIS and Lens distortion correct.
I think with this 3.8mm 16MP lens it can be even better!
@o2warp - it shoots 2.7k at 45mbps and 4k at 60mbps still ?
Answer available :-)
Resolution Bit Rate(Mbit/s) Size per 1 minute(MB)
4K P30 60 450
4K Ultra P30 60 450
2.5K P30 45 337.5
1440p P60 45 337.5
1440p P30 30 225
1080p P120 60 450
1080p Ultra P120 60 450
1080p P60 45 337.5
1080p Ultra P60 45 337.5
1080p P30 30 225
1080p Ultra P30 30 225
960p P120 60 450
960p P60 45 337.5
720p P240 60 450
720p Ultra P120 60 450
720p Ultra P60 45 337.5
480p P240 60 450
@zcream I don't know yet. I didn't get any inform about bitrate from YI Tech.
All I know that is firmware history but there is no inform about bitrate.
Xiaomi has any plans for reducing price?
@trevmar - I am on 1.1.0 fw, like you, but can't see your "2.5K mode 2560x1520" as mine says in 2.5K mode: 2560x1920 and it's 4:3, not 16:9. Am I missing something..?
Few days back was $206 from EU warehouse.
Be careful when ordering from GearBest. I waited 15 days and they didn't ship it, and I canceled the order
Shit happens, but I never had issues with them.
They can be slow to ship some rare items, but usually they indicate such things.
Did you guys have to refocus the Yi 4K lens? Mine was factory set a bit too close to get sharp on distant objects. Turned it just a bit clockwise and now is fine - from about 60cm to infinity.
@Readbook - as far as I know, Gearbest is the only official online shop for Xiaomi 4K.
Sale for EU warehouse now
And Yi 4K has been already hacked - at least the bitrates - that goes up now to 90-150Mbps (instead of 60Mbps).
Is the quality measurably better with the higher bitrates?
Significantly better, to my eye. Example:
https://github.com/irungentoo/Xiaomi_Yi_4k_Camera
Linky for bitrates
Valdi99, can I ask you what you see better in that video? I see an over-sharpened image whose field of view is being chopped around as the camera moves (perhaps they have the 'stabilizer' on?). What do you see the higher bit rate is imparting to that image?
More details, less compression artifacts - basing on my own tests, not the example above.
