Does anyone know if dual IS works with zuiko 12 100 mounted on a G80?
No, it works only with Panasonic lenses.
Have anyone tried G80 with metabones speed booster ULTRA 0.71x Canon EF? Sample footage?
Comparison IBIS stickyness before and after FW fix:
Panasonic G80/G85 image stabilization freezes in cold?
Not my example but I shoot much in cold winter conditions with my GH4 and have not seen this issue with lens OIS (My 14-140mm II vibrates always in hot and gold weather). I hope the GH5 IBIS will not have this issue.
Sensor progress stopped
https://www.dxomark.com/Reviews/Panasonic-Lumix-DMC-G80-G85-sensor-review-Impressive-IQ
It is strange that GH4 has the best sensor and the best iso score but still worst high iso video.
As far as I know all of sensor scores are calculated from stills raw photos.
I wonder how Panasonic can change a good RAW sensor to bad video sensor? I think GH4 has more FW processing power than G85. At least 4k AF is much faster in GH4. Maybe G85 LSI has still more power and wisdom.
If the G85 good high iso is done by LSI processing I wonder if it is possible to get similar result with GH4 and post processing.
Look at http://www.personal-view.com/talks/discussion/comment/226982#Comment_226982
G85 use newer LSI, more powerful. Including much better noise reduction using multiple frames.
If GH4 had raw it will be certainly possible. :-)
@Vesku "It is strange that GH4 has the best sensor and the best iso score but still worst high iso video." Do you have a source for this "worst high iso video" comment?
All the later cams like the G7 and GX85 have noticeably better ISO performance than the GH4. The grain is finer, and there is less of it.
ISO test
PV Deals price dropped
http://www.personal-view.com/deals/cameras/panasonic#panasonic-g80-g85-g8
Here's a test I did with the Lumix G80/G85 (whatever!) plus Metabones Speedbooster 0.71x and Tamron 24-70mm 2.8 VC Lens. In short - IBIS is working great with it now, but no Dual IS. When used with this camera, the VC (Vibration Control) is disabled to allow the IBIS to function properly. At least that is my understanding of it. The VC works perfectly with my GH4 + SB
the camera when used with anamorphic lenses creates a mesmerized effect that destroys image.
my worst fear is that GH5 will have same exact issues with stabilazer too...
yiannis: any example of that?
Thanks Yiannis! Yeah, I guess GH5 will do the same...
