Panasonic G80 / G85 / G8 4K 5-axis stab magnesium monster
  • 511 Replies sorted by
  • anyone can confirm that works fine on it both the Metabones XL (0.64x) & T (0.71x) SpeedBoosters? Thanks in advance!
  • @tylerknight I think you are right--I saw a couple more tests that looked as good at several focal lengths.
  • Really cool feature @vesku thanks for pointing that out!!
  • Does G85 users know that pressing some FN button 2 seconds you can assign a menu item directly. Or check what it is.
    I must test if my GH4 works the same way. -edit NOPE.
  • @drdave The issue has been completely fixed! I'm assuming you're referring to the video of the handheld 100-400mm at 400mm.
    The GX85 shows the same as the g85 at that focal length for video when handheld. That's an insane expectation to be able to shoot handheld at that focal length!
  • So, in other words, Panasonic have almost but not quite fixed the problem that the previous camera does not have.
  • @scot
    I bought the kit, because as much as I love my 12-35, I feel the reach isn't quite enough. The 60mm reach is a really nice bit of extra zoom when you're walking around. Having the weather sealing is definitely a bonus too as I'm used to it with my 12-35. I would say the IQ is quite incredible actually! I have the MKI version of the 14-140 and it is quite soft through the range especially at the zoom, but having tried the MKII, I know it is quite sharp all the way through so it really depends what sort of range you're looking for.
  • I have a question for those who purchased the G85 with the 12-60 f3.5-5.6 who might also have the 14-140 f3.5-5.6. Do you feel the 12-60 has an IQ advantage over the 14-140? I ask because even though there is a wide advantage and weather sealing without an IQ advantage I will probably sell the 12-60 to put money towards faster primes. If it had been at least f4 thru it's zoom range I would be more inclined to keep it. What do you think? I should add I have the Lumix 12-35 f 2.8 and the Olympus 9-18 already.
  • Would that help with the z-axis issues when walking you sometimes get with handheld gimbals?
    What exact issues? Bumping from steps?
    In this case you need to think if few millimeter movement of sensor can fix few centimeters bump (for untrained person).
  • What about using the G8 with a gimbal in combination with IBIS turned on? Would that help with the z-axis issues when walking you sometimes get with handheld gimbals?
  • The firmware update was to correct the visible recoil or bounce-back effect that happens in video mode when panning the camera. I’ve now shot more video with the camera and there is an improvement with the updated 12-60mm kit lens and at common video panning speeds many would struggle to spot it. However, as you can see from the video above, the problem persists with the Panasonic Leica DG Vario-Elmar 100-400mm f/4-6.3 lens. The narrow angle of view of this lens makes any movement much more obvious.
    From 43rumors.
  • G7 + Gimbal is great that being said Gimbals are kind of a nuisance to work with IMO especially with G7 as battery changing requires removal of camera and rebalancing
    By idea it must not need any rebalancing. Remove camera with QR plate with market distance, change battery, install at same position. Few seconds.
  • @yskunto G7 + Gimbal is great that being said Gimbals are kind of a nuisance to work with IMO especially with G7 as battery changing requires removal of camera and rebalancing. There are things they can do like make shift jib when Mounted on a monopod which is great. If I were you I'd spend the money for the IBIS it can do much of what a Gimbal can and doesn't get in the way to do it. Than save for a Gimbal for those special things they can do or rent when necessary.
  • @Grimor will you dump the gimbal for dual IS 2 only for works or you feel G7 + a gimbal is a better option in order to have nice stabilized footage?
    I am calculating a G7 + a gimbal vs G8 because both will cost the same amount of money to upgrade from old GH.
  • For ocasional handheld shoots is a great improvement. Gimbal + IBIS could be killer combination!
  • My questions might dumb, but I really curious about what other people tought about.
    After most of you have sufficient experience with Lumix G8, do you feel that dual IS 2 reduces the need of a gimbal or a glidecam? In what occasion do you feel that a kind of stabilization is still required? Thanks
  • Just went outside a tested a few lenses.
    A manual focus vintage lens to test ONLY sensor stab, the 12-60 kit lens with Dual IS 2, and the 12-35 f2.8 to test Dual IS
    Shot in 4K 24p 1/50th Exported in 1080p
  • First test online with the new firmware:
  • Updated too! and working fine. (But my opinion in this area is not so valid because the isue was not so bad to me before.)
  • The new firmware is AMAZING.
    It completely fixes the issues that users were experiencing before and I have spent the morning out shooting with it in various scenarios. It is noticeably better than the GX85 which was already amazing on its own, but the Dual IS 2 is definitely a step forward from that after the update.
    I'm looking forward to getting out shooting more with it and posting the results! The G85 is back in the lead!!
  • Agreed, the 1.1 fw fixes the video stab issue (tested on voigtlander 25mm).
  • Just updated my G80 and it's fine, no more jerky jumps on pans ( horizontal and diagonal), and it still feels steady when not moving. Tried with 12-60 I.S.2 and 14-140 MegaOIS lenses. Well done Panasonic.
  • Firmware structure
    GX8
    • loader1
    • loader2
    • loader3
    • program
    • storage
    • postboot1
    • postboot2
    • postboot3
    • postboot4
    • postboot5
    • dram_sleep
    • eep_ow_a
    • eep_ow_b
    • eep_adjfix
    • music
    • osdover
    • osddata
    • koutei_kao
    • avchd_info
    • eep_net_a
    • eep_net_b
    • focus_selec
    • dummy
    GX85 aka MC262
    • loader1
    • loader2
    • loader3
    • program
    • storage
    • postboot1
    • postboot2
    • postboot3
    • postboot4
    • postboot5
    • dram_sleep
    • eep_ow_a
    • eep_ow_b
    • eep_adjfix
    • music
    • osdover
    • osddata
    • koutei_kao
    • avchd_info
    • eep_net_a
    • eep_net_b
    • apu_boot
    • apu_inst
    • usbcharge
    • focus_selec
    G85 aka MC361
    • loader1
    • loader2
    • loader3
    • program
    • storage
    • postboot1
    • postboot2
    • postboot3
    • postboot4
    • postboot5
    • dram_sleep
    • eep_ow_a
    • eep_ow_b
    • eep_adjfix
    • music
    • osdover
    • osddata
    • koutei_kao
    • avchd_info
    • eep_net_a
    • eep_net_b
    • apu_boot
    • apu_inst
    • focus_selec
    Quite clear that it is almost same LSI with firmware NAND memory being double of that of GH4,
    G85 and GX85 are being extremely close.
