Insane price for such a great lens. That and it's 14-35 sibling are optically equivalent to a set of very high quality primes; sharp edge-to-edge wide open. I'm surprised no one has thought of rehousing them as cinema lenses.
Can get used one for $999 https://www.bhphotovideo.com/c/used/404517/Zuiko_Digital_ED_35_100mm.html
Like LPowell, I too am thinking of selling my Olympus 35-100mm. Didn't know the manual focusing actually uses a transmission motor, so it is not completely mechanical focusing, which kind of defeats the idea of true manual focus with helicoil smoothness. Plus the focus ring needs camera power to work! Interested buyers can look in Marketplace for it!
Should I get the Olympus 35-100mm f2.0, or get the Tamron 70-200mm f2.8, and then get the Metabones speedbooster for the Tamron to change it to 50mm-140mm f2.0 (35mm equivalent). (I assume the speedbooster wouldn't work on the Olympus because it is a four thirds lens, right?)
So, on the GH2, effectively, I would have the Olympus at 70-200mm or the Tamron at 100mm-280mm.
I would use if for wedding videography, always on a tripod, with a rig that would have lens support. Focus by wire is not a problem for me. I don't necessarily need a Matte Box or Follow Focus.
Seems like the Tamron would be a better value, assuming the speedbooster works. That would be a total of around $1500 new. Whereas, the Olympus is $2600. Also I think the extra reach on the Tamron (with speedbooster, up to 140mm, or 280mm on m43) would be a bigger advantage for me than the wider view of the Olympus (at 35mm, or 70mm on m43). But would image quality suffer too much with the speedbooster?
Thanks for your help.
