EF 16–35mm f/2.8L III USM Refurbished, $1495
https://shop.usa.canon.com/shop/en/catalog/ef-16-35mm-f28l-iii-usm-refurbished
Good deals
Canon EF 16-35mm f/2.8L III USM w/ PaintShop Pro X9 $1749
Code - TMAF177107755
http://www.buydig.com/shop/product.aspx?sku=EMCN163528LIIICO
Canon EF 16-35mm f/2.8L III USM w/ PIXMA PRO-100 $1799
Code - AMTMF207K17
Mail in rebate - https://thereal.buydig.com/nimages/CanonMIR_083117.pdf
Lens made it to the gear of the year list
https://www.dpreview.com/opinion/9906900198/chris-gear-of-the-year-part-two-canon-16-35mm-f2-8l-iii
Review
At 16mm the lens performs very well wide open, so much so that we start to see the effects of diffraction by F5.6. As you move through the focal lengths there's a drop in overall lens sharpness, especially wide open; the worst of which can be seen at 28mm where you have to stop the lens down to F5.6 to achieve the best result. Corner sharpness suffers as you move toward the longer end of the lens. By 35mm the best overall result is at F5.6, with a tiny cost to central sharpness.
https://www.dpreview.com/reviews/updating-a-classic-canon-16-35mm-f2-8l-iii-lens-review
Samples
https://www.dpreview.com/samples/3351236331/canon-16-35mm-f2-8l-iii-real-world-sample-gallery
Comparison with Tamron
Review
Test with measurements
From a resolution standpoint, the Canon 16-35mm f/2.8 Mk III is the best f/2.8 wide-angle zoom available.
https://www.lensrentals.com/blog/2016/10/canon-16-35mm-f2-8l-mark-iii-optical-bench-tests/
Optical construction and MTF
In addition to the new EOS 5D Mark IV DSLR, Canon is also introducing two EF-Series L-series lenses as well as a variety of EOS accessories. The new EF 16-35mm f/2.8L III USM Ultra-Wide Zoom Lens features a large diameter GMO dual surface aspherical lens and ground aspherical lens, f/2.8 aperture throughout the entire zoom range, fluorine coating, improved durability and is dust and water resistant. The new EF 24-105mm f/4L IS II USM Standard Zoom lens features an improved four-stop image stabilization as well as ghosting and flare reduction with air sphere coating. The Canon EF 16-35mm f/2.8L III USM Ultra-Wide Zoom Lens is scheduled to be available late in October for an estimated retail price of $2,199.00 and the EF 24-105mm f/4L IS II USM Standard Zoom Lens is scheduled to be available in late October for an estimated retail price of $1,099.00.
Full time manual focus means that in AF mode you can adjust focus without any switching. It is such for most USM lenses.
What's the difference between Full-time manual focus and manual focus?
Added more specs and photo.
