Seagate 60TB SAS SSD
    It is not available yet, only in 2017.
    But it will have cheap 3D TLC NAND chips with around 100-200 rewrite cycles life.
  • 2 Replies sorted by
  • Samsung
    Samsung introduced its 4th generation, 64-layer triple-level-cell V-NAND flash memory that pushes the envelope of NAND scaling, performance and storage capacity. Stacking 64 layers of cell-arrays, the new V-NAND can increase its single-die density to an industry-leading 512Gb and its IO speed to 800Mbps, which further distinguishes Samsung’s technology leadership in three-dimensional NAND cell structure design and production. Starting in August 2013, Samsung has previously introduced three generations of “industry-first” V-NAND products with 24, 32 and 48-layer vertical cell-array stacking technologies.
    World Largest Capacity Drive − 32TB SAS SSD − for Enterprise Storage Systems
    Samsung’s latest Serial Attached SCSI (SAS) SSD is the world largest single drive ever introduced to the industry based on 512-gigabit (Gb) V-NAND chips. A total of 512 V-NAND chips are stacked in 16 layers to form a 1-terabyte (TB) package and the 32-terabyte (TB) SSD contains 32 of those packages.
    By adopting a new 4th generation V-NAND design, the 32TB SAS SSD can reduce system space requirements up to 40 times compared with the same type of system using two racks of hard disk drives (HDDs). The 32TB SAS SSD will come in a 2-5-inch form factor and be produced in 2017. Samsung also expects that SSDs with more than 100TB of storage capacity will be available by 2020, thanks to continued refinement of V-NAND technology.
  • This will solve my storage problem for a 3 years!
