I ordered 3 of these and they showed up today - really nice/small/portable and they're surprisingly bright at full strength. They come in cute little pouches with clips too. I think they might work as the beginning of a really small portable lighting kit for my A7s and/or A7rII, potentially combined with Lumecubes (I have a small handful of them on the way too).
The M9's feel light enough that they could easily be attached to things with moderately-strong tape if one didn't want to bring with a bunch of light stands to go with them (though the next step is figuring out what can be done for really tiny light stands - a few small gorillapods might be a place to start)
anybody know where this is ready to ship in Europe? aputure's eu store has it but they charge an absurd amount to ship. I am in Sweden.
Check out my review of this light. The Aputure Amaran AL-M9
The audio goes completely out of sync at 6:53 or so and it makes the rest of the video pretty much unwatchable.
Our video
Later we'll have separate post and may be video about lab measurements.
Thanks for good video.
Out SMPTE interview
PV Lab measurements, CV600 spectrometer, Russian lab processing
Focus on TM30 and CIE 244 and look for color distortion and Rf values.
AL-M9 is very good little light with good light quality.
Color temperature
CRI color quality
CQS color quality
TLCI 2012
TM30 color quality
TM30 details
CIE 244 2017
PV Lab measurements, Lusin spectrometer, Russian lab processing
Different batch light, different place, different spectrometer.
Only basic items to see difference.
Color temperature
CRI color quality
CQS color quality
TLCI 2012
TM30 color quality
BIRTV interview
Note how M9 controller can't keep up output
Yep, thanks. Very useful observation.
For large lights it is not a problem as controller keeps up output.
It is problem with controller design, I believe, made intentionally as if it'll properly rise current during battery voltage drop battery won't last much.
Aputure M9 PWM at 100% (battery at not full fresh charge)
You can see that controller dim leds even at 100%.
See above that controller can't keep output level.
PWM Frequency is 39,8Khz
Aputure M9 Inside
Overall pretty cheap construction with most prominent element - large battery
Holes are made for battery cooling mostly
Overall cooling design is bad, all you have for heat spreading is front board with leds.
And it is covered with diffusion almost all the time.
Another reason for this holes can be for them to act as thermal barrier and not led heat each other too much, but idea seems to be poor.
Simple small board with passive components and STM controller
Notice usage of two same black colored wires for led output, really bad things happen at manufacturing.
M9 Thermals
Most hot parts are solid middle lines of led board and also controller board near USB connector.
