Can you recommend budget tablet prompter in €150 range? Something like this but not with another €150 tor tax and shipping.... http://caddiebuddy.com/teleprompter/ Parrot is to small unfortunately ..
OK, I bought the Parrot V2. It looks just like the picture above. It's small, repeat, it's small--imagine reading from a cell phone. Image is sharp and clear, and there is no light leak or bleed through, as it uses a sealed screw in filter instead of a hood for the back.
It comes with free software for Android and the "other" phone--the software is basic but good: font size, margins, speed, orientation.
I didn't buy the bluetooth remote but for another $20 it might be a good idea.
Minor complaints: the included screw in filters have a lot of paint on the threads, so it's a bit squirrely getting them into the lens. Also, they come in large sizes, if you have m4/3 lenses you will need a step down adapter, no biggie. The 58mm fit my Canon camcorder.
Another minor complaint: the "feet" of the retaining clip sit on the glass of the phone. I'm pretty sure it won't mark the glass, but if you put the phone in a case that has some ridges on the sides (so when the phone is upside down there is like 1-2mm space, good idea anyway) the ridges will protect the phones surface.
Verdict: very lightweight, very portable, a good buy, but it is small. Now small is good in that you are always looking straight at the lens, but it's a tiny bit of text. Tip: Add spacer lines to make timing breaks.
Parrot 2
https://www.kickstarter.com/projects/957253584/parrot-2-the-most-portable-and-affordable-teleprom
                  Free windows prompter software
An even cheaper option is to use a longer lens and have the tablet just below the lens using a lighting stand.
I use an 85mm on the BMPC/CC and a first gen iPad. I have a Datapro 300, but prefer the simple under the lens arrangement. The software is a free App and lets you set the text size and speed.
Just check tablet topics here. No need to hack Kindle, as cheaper and better tablets exist. As for big battery. No one prevents you to use 5V battery connected to power input.
There must be a ridiculously cheap android tablet that will work. I suppose have a truly monster battery would be a handy feature, plus good BW contrast. Maybe a hacked kindle.
I agree it's important but in our tests people weren't able to distinguish between a talent looking directly at the center of the lens and slightly above it. Not one person could tell the difference. The show didn't have a lot of tight close ups though.
This is an interesting topic to me as I am building a studio next to my house.
I shall keep my eye on it.
@goanna That's cool concept .. Similarly I feel like fool for not having thought of it.
@brianluce I have to disagree with you. The eye-line is incredible important. While viewers may not be able to comment that the speaker is 'not looking to camera', IMHO, the effect of 'not looking directly to camera' can be taken as insincere or dishonest - why can't you look me directly in the eyes.
@DrDave .. second hand iPad 1.
What would be a cheap tablet that would work with this device that would give you the biggest image?
Here's a quick drawing of my periscope-style teleprompt. Sorry, I'm 1600km away from the item at present...
(Whoops, I should have marked at lower left, "InterviewER or Script"
                  I built my own eye-to-eye using silvered glass and a mirror. It's built to make the talent look into the interviewer's eyes rather than a script - but it can be used as a teleprompter, too, except text need not be laterally inverted (as in mirror) so you can scrawl a quick script onto paper instead of type it out and invert it. no need for a computer.
Cost: $200 and it's bigger (as in A4 paper-size glass) and better than the $1000 commercial models.
There are lots of these things around and I felt a fool when I discovered I hadn't actually thought of it first after all! :-(
But see http://www.eyedirect.tv/ for an idea.
Yep, it is very useful stuff to have.
Have to try this. Does block some of the light, but it will center the look of the speaker right on the cam.
Small video about prompter from http://www.ebay.com/sch/sgrovs/m.html
