The HDMI output on my GH2 just suddenly died. I'm using 7" Lilliput on it, nothing changed, all of a sudden it just stopped working. First, the monitor just said "no signal" but after some tweaking on/off, it just started to stay black or blue as it was receiving a signal but didn't know what to do with it. An older flat TV says "signal not supported" and a brand new LG doesn't recognize anything. The GH2 clearly thinks it's connected to external monitor, as the on-board screen flickers when connecting, ExTele is disabled, etc., so everything seems normal at that end. Tried different cables and resetted the firmware.. What else to do or try?
Make good macro of connector on camera side. Most probably it is issue with it.
For next time - best is to use small cage like cable fix rig, and either short coiled cable you never remove or very short converter.
