Sony A7s II 4K low light beast topic
  • 232 Replies sorted by
  • @RottenCarcass We don't really do "production" stuff, its more of a run-and-gun type of stuff (automotive journalism), and having a really compact setup is a priority.
  • @mk47 doesn't that just mean that you should always use a monitor with the AS7II? I mean, some folks already use it because there is simply more info available, but maybe this is another reason?
  • Thing that annoys me the most about this camera is how deceiving the display brightness can be.
    Set it to the "sunny day" or whatever and it will be way brighter that the actual recorded footage. Also when shooting in 100fps the display brightness is default only, which is way too dark.
    After a day of shooting on both settings during i ended up with a bunch of footage being either way under- or overexposed.
    Now im always using the 100+ zebra at all times, because relying on the display alone is totally worthless.
  • New firmware - Firmware Version 2.10, only change is ability to use SDHC for XAVC S
    http://www.sony.com.au/support/product/ilce-7sm2
  • One little correction to my post above: I have discovered the custom zebra function, which allows you to set zebra levels to 108 (+/- 1). In video mode this is very useful, as it does show the sensor clipping correctly. In raw photo mode of course it does not help. Well, if anybody has some more tips on the things mentioned above, let me know!
  • A7Sii and A7Rii Tutorial - How to Jam Syncing Timecode
  • @nomad you are most welcome!
  • Thanks, very detailed and helpful!
  • Hi folks,
    now that I have used the Sony A7s II for more than 3 months it is time to write about my experiences. I am coming from the Lumix GH1, GH2 (both hacked), then used a BMPCC for 2.5 years and now 3 months the Sony.
    Pro's: - fantastic overall package feature wise, ticks most of the boxes, gorgeous fullframe look! - very small footprint for fullframe, almost the same as the GH2, can be used out of the box to shoot (OK add an external shotgun mic to the equation) - IBIS is fantastic for handheld work: all my lenses including old Canon FD's, FL's, etc... are now stabilized and it really works! - excellent viewfinder - on all cameras before I was always using the rear screen and thats where a flip out screen is an absolute must. On this cameraI I find myself using almost exclusively the viewfinder now - Resolution (4K & FHD) is gorgeous, framerates up to 120fps in FHD fantastic (although 2.2 crop but OK) - Good dynamic range: SLOG 2 or the cine gamma 4 modes are almost equal, the look however is different (cine gamma 4 is more like video, SLOG2 has more that organic look) - both can be tweaked nicely (but not too much) in post - but the (usable) dynamic range is about 1.5 stops less than the BMPCC! I would say the Sony has around 11 usable stops (which is very good), whereas the BMPCC has more like 12.5 to 13. With the BMPCC you can access all the stops, with the Sony the codec starts to fall apart if you push to far. - of course lowlight, but I do not find myself using those high ISO's much. But good to have.
    Con's: - I do not get it, but basic basic basic features do not work on the Sony: - focus peaking: is highly inaccurate to a point where it is useless. Peaking shows everything in focus where it is not. I do not understand that as the BMPCC for example has a very accurate peaking. It just works and you can rely on it. Not so with the Sony. - zebras: in video mode usable, but it only shows clipping up to or above a luminance level of 235. In Slog2 or Cinegamma 4 you can record up to 255. Hence you have to guess that within the blinking zebra region there is still some usable information but you are left to guessing. The BMPCC for example shows EXACTLY where the sensor clips with the zebra. Very usefull - zebras: in photo mode the zebra is completely useless. In RAW you have ample of info in the blinking zebra regions (up to 2.5 stops more) - again you are left to guessing. I simply do not understand that: this is a mirrorless camera where you expose the sensor and you just read out the luminance value and display if you are above or below? There is no mirror which prevents the sensor from exposing and thereby reading the values correctly? Why is this not possible and you are left to guessing? Thats beyond me. - Codecs: Using the BMPCC I completely forgot that codecs can be an issue. Using the Sony it reminded me again of the early GH2 days without a hack (yes that was 5 years ago!). 100mbits/s in 4K is too low. 100mbits/s for 120fps FHD is too low - lots of magenta macroblocking in the shadows, even in static scenes. Is OK in Cine gamma 4 because you can shoot at lower ISO (but you loose another stop against SLOG2), but in SLOG2 you are shooting 1600ISO in 4K and 3200 ISO for 120fps FHD - and this does not work well at least for 120FPS. - SLOG3 sounds nice but shows banding, to a point where I have stopped using it. - Sony color science is OK and can be tweaked (but not too much due to codecs) but looks a bit yellow, video-ish. BMPCC has so much richer colors, tonality, organic look. I am really missing that.
    I will still find myself using the Sony for most of my work from now on, as it is overall a fantastic package and ticks most of the boxes for lightweight do -it - all travel video / photography. But on a dedicated video job I will continue to use my BMPCC (of course rigged up).
    Hope that helps some users out there! Let me know what you think and how your experiences are!
    Gunther
    For the serious videographer, or movie maker, the advanced options available for high quality video output that the Sony Alpha A7S Mark II provides will be most welcome, and compared to some of the competition, particularly traditional video cameras, the A7S Mark II will appear to be excellent value for money, even when compared to some of the other full-frame cameras available from Nikon and Canon.
    https://www.ephotozine.com/article/sony-alpha-a7s-mark-ii-expert-review-28283
    800 x 529 - 36K
    The A7S II's 12.2 megapixel sensor continues to provide excellent results from ISO 50-12,800, while ISO 25,600 and 51,200 are fine for making smaller prints and web use. The fastest settings of 102,400, 204,800 and 409,600 are very noisy but astonishingly do let you shoot in almost total darkness.
    http://www.photographyblog.com/reviews/sony_a7s_ii_review/
    800 x 543 - 100K
  • Sony A7s II vs A7r II (APSC) vs A7r II (full-frame): 4k UHD / 25P / 100 Mbit
  • Eyecup test
