CAME Optimus single hand gimbal
    This is Single bigger brother
    • can bear around 2 times more weight
    • faster balancing
    • modular
  • 21 Replies sorted by
  • Any idea if this will replace the Came single pricepoint-wise? Or will it be a bit more expensive? If the price is reasonable I might seriously consider buying it as soon as it is released.
  • The weight capacity is about the same as the came single btw, not almost twice as listed earlier here.
    Who told you this?
  • Here, twice:
    1242 x 2208 - 507K
  • I'm also sad that it's $400 more than the single. :(
  • @Hellohogo
    Well, I'll recheck as my source is better.
  • awesome, because it would seem a worthless upgrade at this point.
  • Any update from your source?
  • @Hellohogo
    It seems that you are close to truth. But initial intention was same as in first post here.
  • Damn. That's too bad. I was hoping it would be double. Do you know it's going to ship?
  • Here you see my first footage that I have taken with the new Came-TV Optimus gimbal. It is filmed with a GH4 and a 12-35 lens. It works really well can be used in inverted mode as well, as seen in the video. The little shaky part a 0:52 is due to my hand touching a seat and not caused by the gimbal
  • In this video you see the second footage that I have taken with the new Came-TV Optimus gimbal. In a car on a bumpy road first held normally, then in inverted mode held out of the window near the ground.
    It is filmed with a GH4 and a 12-35 lens. I will later also make an unpacking and review of this nice gimbal from Came-TV.
  • In this video you see the review of the Came TV Optimus gimbal, including the unpacking, explaining of the features and the comparison between the Optimus and the Single, both from Came-TV for personal-view.com It is a great step in the right direction, coming from the Came-TV-single, which was very good already.
  • I recently go the 2 handle bar for the Optimus. Later, I wil make a short video but for now a few pictures:
    These are the parts
    Assembled, with he camera on top with the remote control
    Camera on top
    Assembled with the camera at the bottom with the remote control
    Camera at the bottom
    The remote control. Small button for on and off as well as for mode switch, large button is the joystick
    One can attach a monitor or microphone at the handle bar. Good.
    It works very well and of course it is better if you film longer sequences, when you can hold it with 2 hands.
    2175 x 2538 - 662K
    3948 x 2394 - 1M
    3837 x 2199 - 1M
    4035 x 2295 - 1M
    1670 x 1772 - 667K
    1694 x 1772 - 670K
    1772 x 997 - 230K
