Android remote control mod
Interesting info about Samsung long video damage issue
I am fairly certain know how the "limit" works, there seem to be two kinds of bugs/memory leaks:
- (probably audio) error after ~1:16:48
- (video or something similar) error
https://github.com/ottokiksmaler/nx500_nx1_modding/issues/46#issuecomment-226930233
Check this link, as it also contains small tool to make auto restart of video (you will lose around 3 seconds)
NX3000 has really good internal design
Main board have simpler and more integrated result compared to any Japanese company (and Panasonic is still leader among them).
Plus they also throw out all flash related things.
                  No, it does not work with NX1000 for now.
From practical standpoint for single camera - GX85
For fun and drive - NX500, last of its kind, http://www.ebay.com/itm/Samsung-NX500-4K-Video-Record-Mirrorless-Camera-k-w-16-50mm-Zoom-Lens-Black-/331831874089
I really hope for hack making non cropped mode available, as well as good bitrate 2.5k.
Guys who work on it made progress by making it work without quite complex Bluetooth usage for hacks activation. Note that video bitrates is already implemented this way and work with latest firmware.
https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/video-bitrate-mods/nx-patch
https://github.com/ottokiksmaler/nx500_nx1_modding/tree/master/nx-on-wake
Thanks guys, I managed to install the 'hack' successfully.
@fancydancer No dummies video necessary. A dpreview forum member named 'Kino Seed' created an easy SD installer that is simple, relatively fast, uninstallable, and provides in-camera menus for customising bit rates, amongst other mods/hacks thanks to the work of 'vasile' and 'otto k': http://www.dpreview.com/forums/thread/4000563
As a longtime follower of the GH2 hacks -- shoutout to legends @vitaliy_kiselev and @driftwood -- which weren't that hard to install, it doesn't get much easier than this unless Samsung did the 'hacktory install' themselves. You'll see what I mean.
Nice to see a few nx300 users here. I recently (after having this camera for 2 years now) discovered some major bugs in my videos after watching them back. I noticed what was flashing in objects or this weird macroblocking going on!!! I looked the problem up and found out that samsung messed the settings up for the codec and its on a low setting instead of high. I cant remember the specifics now, not pleased though and because these are discontinued I doubt we will get any firmware fixes.
Man I would love to see someone hack this thing and fix the firmware on it, I doubt this could be fixed with a script? I downloaded the open source and peeked around but its hard to understand that stuff if you dont know what your doing.
Any update on NX300 hacks, I would like to adjust the bitrate of the 24p mode to match the bitrate of the 60p mode...
It needs work, I think. I do not see any good public firmware packer/unpacker for now.
Btw, I have NX300 also.
It is not much for dummies now. But not too hard.
I hope some one will post a dummies guide step by step video on how to adjust the nx1 bitrate.
I really don't have a clue on how this works. But your understanding must be very welcome to find out how to get the best of these cameras.
Is there any method for disabling the crop on the NX500 in 4K? If that's doable, then I'm gonna have to pick one up.
I think they have no idea.
No.... not doable Isaac. As far as i know, you can get 2.5k with no crop.
All that they done for now is just switch mode numbers. And bitrate.
Making no crop 4K require understanding all mode settings difference and initializing.
So, may be it can be done.
No.... not doable Isaac. As far as i know, you can get 2.5k with no crop. I'm more concerned about the possibilities with a Magic Lantern like on this cameras. With a new codec, or raw via hdmi, we could get way better images with these samsung cameras. At the moment the macro blocking and h265 are kind a bummer.
The quality looks pristine, wow that's clean. A shame that Samsung seems to have abandoned this market. They got things 95 percent right with the NX1.
That's some great news, Vitaliy! I really appreciate the benefits of these hacks for low budget filmmakers all over the world. You can't imagine how expensive is a decent camera here in Brazil.
I got NX500, will get it quite soon, will try to make some sane guide and look at this.
Now they are trying to disable the auto noise reduction and the auto sharpness of the camera. But it's hard to understand how it works... So far.. They didn't find out where this codes could be located.
And another guy is trying to figure out how to make deep changes on the system. Maybe replacing the codec (h265 sucks...) and other stuff.
I wish some guys at Magic Lantern team could forget about Canon cameras for a while and help this guys with the nx1. The camera is awesome.
yes.
